Tial 50mm BOV.
Old Jan 30, 2004 | 05:30 AM
Hoosier Daddy's Avatar
Default Tial 50mm BOV.
Anyone using this BOV? I heard it's similar to the Greddy Type R. Does that mean it's only good for higher boost? Anyone know how it sounds? Any feedback would be appreciated.
Thanks
Old Jan 30, 2004 | 05:39 AM
b18bturbo's Avatar
Default Re: Tial 50mm BOV. (Hoosier Daddy)
The tial unit can be used on setups as low as 5psi all the way up t0 35+ psi
The tial has optiosn for two springs 7psi and 11psi in there bov.
The units vent directly to the atmoshpere and sound like swish of air. Overall its the best bov in my opinion on the market.
The 50mm size helps out compared to the other manufactures
Old Jan 30, 2004 | 05:46 AM
PM-Performance's Avatar
Default Re: Tial 50mm BOV. (b18bturbo)
i have it , but i haveny heard it yet
Old Jan 30, 2004 | 05:51 AM
M.K.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">The tial unit can be used on setups as low as 5psi all the way up t0 35+ psi
The 50mm size helps out compared to the other manufactures</TD></TR></TABLE>
Which rate (7 or 11 psi) spring should people go with...I know it depends...but if people run low boost on the street, and then bump it up at the track, which would you choose?
-mark
Old Jan 30, 2004 | 05:58 AM
genop's Avatar
Default Re: Tial 50mm BOV. (M.K.C.)
I would get a 7psi spring since you can always raise boost with a boost controller, but you cant go any lower than what your spring is rated for.
Old Jan 30, 2004 | 06:03 AM
Default Re: Tial 50mm BOV. (genop)
I can tell you now you might not have the choice, Tial nor the retailers seem to tell anyone that there is a choice in springs.
Old Jan 30, 2004 | 06:05 AM
b18bturbo's Avatar
Default Re: Tial 50mm BOV. (itr206)
i give all my customers a chocie on the bov and wgs.
we have couple silver ones 7psi and 11psi if you want one let me know.
I would reccommend go with the 7psi if you dont plan on boosting 30psi everyday
Old Jan 30, 2004 | 06:06 AM
genop's Avatar
so its just luck of the draw?? or which spring does it usually come with?
Old Jan 30, 2004 | 06:14 AM
BROOD's Avatar
There is no default spring that I have found. If the seller is not awhere that there are two spring options then they would have no idea and are selling you whatever they were suppied with.
I just bought a extra Tial in good shape (used) but it has the heavier spring. Were is a good place to order a replacement 7psi spring?
Old Jan 30, 2004 | 06:15 AM
I guess with Every other shop but Viren its a guessing game .You are better off getting it from Viren . he will steer you in the right direction . All the other shops just list them and the colors and choices in flange types, they never state anything about the spring. and i usually look out for these things too , but Tial has nothing on the site indicating it. So i dont blame the retailers much becuase alot of them dont know what the hell they are selling . Viren has the common sense and experiece to find this stuff out
Old Jan 30, 2004 | 06:16 AM
b18bturbo's Avatar
Default Re: Tial 50mm BOV. (BROOD)
if you need one i have springs for the bov as well got tons of it actually
Old Jan 30, 2004 | 06:21 AM
will it really matter much if you have the heavier spring in if your not running super hi boost all the time?
Old Jan 30, 2004 | 06:30 AM
b18bturbo's Avatar
it only matters on the drag guys like mustangs running 25+ psi daily not on our cars taht vary boost from 7psi ot 20psi daily and then 30psi at track once in while if it was drag car i would get he 11psi spring on street car 7psi spring
Old Jan 30, 2004 | 06:31 AM
but if i have the 11psi will it affect my car? i dunno whats in it , im too lazy to take it apart
Old Jan 30, 2004 | 06:32 AM
b18bturbo's Avatar
it shouldnt effect it if you run more than 11psi std at least thats what need to open and close it correctly
Old Jan 30, 2004 | 06:43 AM
I have a 10psi spring in the wg. so at worst ill be running 10psi , but more thna likely ill run at least 1bar for the street
Old Jan 30, 2004 | 07:13 AM
Thanks for the replies guys
Anyone have any experiences with it?
Old Jan 30, 2004 | 07:38 AM
Soon_2b_evil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">i have it , but i haveny heard it yet </TD></TR></TABLE>
Old Jan 30, 2004 | 11:32 AM
bluebullet's Avatar
I have one and it sounds bad *** at only .3 bar (waiting to get tuned for higher boost) sounds like a pissed rattlesnake. I like it.
Old Jan 30, 2004 | 11:35 AM
DaX's Avatar
DaX
Loved
Community Favorite
I bought one also [don't have it on yet] but the dealer did not specify which spring I have. Is there any way to tell when I take it apart which spring I have?
spooledhonda
Sep 19, 2007 08:23 PM
Mugencrxsir1
Nov 13, 2006 09:43 PM
silly sohc
Aug 16, 2006 06:55 PM
Dunc
Jan 17, 2005 05:52 AM
Anubyss
Feb 9, 2004 05:17 AM
