what turbo is this
Old Oct 16, 2006 | 02:50 PM
si0385.'s Avatar
Default what turbo is this
i just bought a turbo but im not sure what kin it is and ive looked and cnat find the part number
im looking for specs anyone know where i cna get them
its a garret but on the exhaust side its got the turbonetics "T" stamped on it and garret on the compressor
its a 60 ar part number 409080-5009 i stamped on the tag on the compressor
anyone know where i cna find this info pleae
Old Oct 16, 2006 | 02:58 PM
BoostedEG6's Avatar
Default Re: what turbo is this (si0385.)
does it look like this? I pulled these pics from another site
If so here is the specs the guy had on it:
Garrett To4b90 Turbo
Part Number 409080-5009
Compressor A/r .60
Exhaust Housing A/r .96
4 Bolt Exhaust Flange
54mm Compressor Wheel
Old Oct 16, 2006 | 04:45 PM
si0385.'s Avatar
Default Re: what turbo is this (BoostedEG6)
yes that would be the one
where did you find the part number if you dont mind me asking
Old Oct 17, 2006 | 03:51 AM
BoostedEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si0385. &raquo;</TD></TR><TR><TD CLASS="quote">its a 60 ar part number 409080-5009 i stamped on the tag on the compressor
right there
Old Oct 17, 2006 | 05:37 AM
si0385.'s Avatar
i ment what website or did you just know it off the top of your head
Old Oct 17, 2006 | 05:51 AM
BoostedEG6's Avatar
Default Re: (si0385.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si0385. &raquo;</TD></TR><TR><TD CLASS="quote">i ment what website or did you just know it off the top of your head</TD></TR></TABLE>
All I did was google "Garrett part number 409080-5009"
Hope I helped you
Old Oct 17, 2006 | 07:33 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (BoostedEG6)
its basically a t04b
.60 ar "E" cover
on center .96 ar t4 housing
its gonna be laggy on your setup and trust me, power levels are gonna suck
Old Oct 18, 2006 | 05:35 AM
si0385.'s Avatar
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">its basically a t04b
.60 ar "E" cover
its gonna be laggy on your setup and trust me, power levels are gonna suck</TD></TR></TABLE>
its goin on a single cam now but it wont be single cam for long... im goning to swap a ls in it some time this winter..
you think it will be laggy on an ls?
i know its not the ideal setup for a single cam but keep in mind i got the entire kit minus the oil lines for 450
Old Oct 18, 2006 | 05:38 AM
adseguy's Avatar
Even on a higher revving GSR you won't like that turbo. Get a hybrid like a T3/T4 not a straight T4 like this one. You won't see full boost till 6k rpm or higher
Old Oct 18, 2006 | 08:17 AM
TIGboy's Avatar
Default Re: (adseguy)
correct me if Im wrong but isnt that the standard TO4B cover not an E.
Old Oct 18, 2006 | 08:59 AM
si0385.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">Even on a higher revving GSR you won't like that turbo. Get a hybrid like a T3/T4 not a straight T4 like this one. You won't see full boost till 6k rpm or higher </TD></TR></TABLE>
im sorry but im really new to this and dont know what the difference between a t3 and a t4 is i was not even aware i had a t4
Old Oct 18, 2006 | 09:34 AM
si0385.'s Avatar
Default Re: (TIGboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TIGboy &raquo;</TD></TR><TR><TD CLASS="quote">correct me if Im wrong but isnt that the standard TO4B cover not an E. </TD></TR></TABLE>
thats what i figured it was a to4b90 and the to4e was a bigger turbo
i really wont see full boost till around 6k, thats gona suck
Old Oct 18, 2006 | 10:59 AM
wantboost's Avatar
Who is Mr Robot?
eh, the difference between the two is minimal and its all about the internal volume of the housing
Old Oct 18, 2006 | 11:18 AM
adseguy's Avatar
exhuast housing .96. On a T4 ....you won't see boost until 6k. I sure you can sell that to a rotary guy
Old Oct 18, 2006 | 12:16 PM
si0385.'s Avatar
ok so what would be the ideal sized turbo on a stock ls... looking for the 300-320 hp range if i can get more great but i want at least over 300
Old Oct 18, 2006 | 01:27 PM
adseguy's Avatar
Don't rephrase the question in a new post.... If you don't believe me that's fine, have people come to this post then.
That turbo will be plenty to give you 300whp. It's probably good for 500 or so (just a guess).
What is your HP goal? Are your internals built? If you want 300whp I'd go with a big T3 or a very small T3/T4 turbo. If you want room to grow then get a nice sized T3/T4 and most will produce 400whp+.
If you didn't understand what I just said then you have a LOT of reading to do so don't post here anymore and go research.
Spoolnb16
Mar 9, 2008 02:43 PM
SL0WEGG
Jan 4, 2006 01:34 PM
baphomet
Jun 15, 2005 05:41 PM
94sohcEx
Apr 5, 2004 03:40 PM
reXem
Aug 31, 2002 06:31 PM
