boosted b16
Old Oct 17, 2006 | 07:29 PM
b16turbobell's Avatar
Default boosted b16
what kinda whp numbers are people putting down with boosted b16's how much boost are they holding and how long,what is a so called safe amount of whp on the motor. what kinda times 1/8th and 1/4 thanks
Old Oct 17, 2006 | 07:52 PM
tokesGTR's Avatar
Default Re: boosted b16 (b16turbobell)
People are usually putting down about searchwhp and searchwtq at about search pounds of boost. They'll hold boost search well, and you can run about search whp on a stock motor. Depending on the chassis of the car, anywhere from search.search at search in the 1/8 mile and usually less than search at 100.searchMPH in the 1/4 mile
Old Oct 17, 2006 | 08:00 PM
Default Re: boosted b16 (tokes1320)
i know where search is at its the big red f^&9en buttom upper right hand side, i have used it but most treads are b16 with gsr cams, or build, sleeved, what im talking about is BONE stock headgasket,intake pistions, cams, and all. i dont understand why people spend the time to be a jack'azz and not the time to help.
Old Oct 17, 2006 | 09:08 PM
Garage 808 Hatch's Avatar
300's, 20ish psi depending on turbo. lasting long time with good tune
Old Oct 18, 2006 | 05:46 AM
orange99si's Avatar
My best on 1/8 mile was a 9.2 with horrible traction problems. at about 9psi (205/50/15 hankook zr212s)
I am stock with a greddy 18g kit. with other minor mods...3inch cat back, lightened flywheel,fluyidine raditator, cometic head gasket
Old Oct 18, 2006 | 01:40 PM
tokesGTR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16turbobell &raquo;</TD></TR><TR><TD CLASS="quote">i know where search is at its the big red f^&9en buttom upper right hand side, i have used it but most treads are b16 with gsr cams, or build, sleeved, what im talking about is BONE stock headgasket,intake pistions, cams, and all. i dont understand why people spend the time to be a jack'azz and not the time to help.</TD></TR></TABLE>
I'll help when you take the time to search properly. 130 threads in FI alone when you search for stock block, and 170 results searching for stock B16.
Of course, maybe it's too much to expect somebody to use some intelligence and seach using wildcards and non-specific words, instead of the exact string of text they're looking for.
ken60202
Feb 15, 2005 06:40 PM
90 integra
Oct 16, 2004 07:20 AM
ZC_Vtec_Civic
Sep 11, 2004 09:21 AM
95civichatch
33
Dec 21, 2003 05:02 PM
FRESH
Dec 1, 2002 02:35 PM
