What is this? Tetra?
Old Jan 5, 2006 | 12:33 PM
Chillin94hatch's Avatar
Default What is this? Tetra?
Can anyone please help me out and tell me exactly what this is and what it is used for. I would appreciate it. The word "Tetra" is on each hanging thing...
Old Jan 5, 2006 | 12:36 PM
raene's Avatar
Default Re: What is this? Tetra? (Chillin94hatch)
They look like fish tank check valves...
Old Jan 5, 2006 | 12:37 PM
coneheadsracing's Avatar
Thats for a fish tank those are one way whatever you want to call them, similair to a pcv valve. I believe they use them for boost control, or to trick the wastegate into more boost. Do a search for something along those lines, should come up with some more info. I'd just buy a cheap boost controller though, ten bucks i think is what i paid.
Default Re: What is this? Tetra? (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">They look like fish tank check valves...</TD></TR></TABLE>
Thats what I kind of just figured out...ha thanks guys
SL0WEGG's Avatar
thats exactly what they are. haha. it bleed's boost so the map sensor does not see it. in essence its a cheap missing link
Old Jan 5, 2006 | 12:38 PM
Default Re: What is this? Tetra? (boostedej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedej1 &raquo;</TD></TR><TR><TD CLASS="quote">thats exactly what they are. haha. it bleed's boost so the map sensor does not see it. in essence its a cheap missing link</TD></TR></TABLE>
Where exactly do you apply them in the turbo set up? Sorry I am not too familiar with missing link either...
Old Jan 5, 2006 | 12:41 PM
*Boostwerks*'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillin94hatch &raquo;</TD></TR><TR><TD CLASS="quote">
Where exactly do you apply them in the turbo set up? Sorry I am not too familiar with missing link either...</TD></TR></TABLE>
In the vaccume line between the TB and the map sensor. They bleed off the boost so the sensor only sees vaccum. It works if your using an FMU for fuel management.
TETRA is a kind of fish...
These can be purchased at any local pet store for under a buck each.
Old Jan 5, 2006 | 12:43 PM
raene's Avatar
When you're in boost they bleed off pressure from the MAP sensor line to fool the MAP sensor into not seeing boost. Use them in combo with an FMU to avoid a check engine light on a boosted car. The car should operate normally under vacuum because they shouldn't leak air into the MAP sensor line during normal driving.
You've obviously gotta use a MAP sensor that is connected via a line, not the OBDI+ stock MAP on the throttlebody.
I've never used 'em so don't ask me for too many details, hehe. I'd highly recommend a tuneable EMS over this type of hack if you're running over 6lbs.
Old Jan 5, 2006 | 12:49 PM
thanks for all the help guys, thats all I needed to know.
Old Jan 5, 2006 | 12:52 PM
boostedcivicsir's Avatar
Mr. Badwrench
thats the cheap version of the missing link
yes 4 years ago i had that setup.
niceguysfinishlast
Mar 22, 2008 02:28 PM
Boring
Dec 10, 2004 12:41 PM
ZCHF
Jan 6, 2004 02:14 AM
ATS*Mark
Dec 19, 2003 11:42 PM
buckfittyone
Jul 15, 2003 06:16 AM
