Cant create more boost?
Old Dec 10, 2004 | 11:26 AM
Boring's Avatar
Default Cant create more boost?
right now im at 5psi. I have a t3/t4 turbo with a tial wastegate. even with a manual boost controller i cannot create more boost? am i missing anything? the top of my wastegate has a small screw in hole but nothings there.
Old Dec 10, 2004 | 11:50 AM
LostCRX's Avatar
Default Re: Cant create more boost? (wc300zx)
first thing first, check for leaks in your charge pipes.
Old Dec 10, 2004 | 12:00 PM
CivicEJ1's Avatar
Default Re: Cant create more boost? (LostCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostCRX &raquo;</TD></TR><TR><TD CLASS="quote">first thing first, check for leaks in your charge pipes.</TD></TR></TABLE>
Boost leak..
Old Dec 10, 2004 | 12:06 PM
Boring's Avatar
Default Re: Cant create more boost? (CivicEJ1)
its funny you say that cuz i do have a boost leak comming from 2 couplers, if i replace them and find no more leaks it should be gravy?
Old Dec 10, 2004 | 12:10 PM
tilt's Avatar
probably
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wc300zx &raquo;</TD></TR><TR><TD CLASS="quote">its funny you say that cuz i do have a boost leak comming from 2 couplers, if i replace them and find no more leaks it should be gravy? </TD></TR></TABLE>
Old Dec 10, 2004 | 12:41 PM
tgreaves's Avatar
Are you sure your manual boost controller is hooked up properly.. Usally if you can create 5psi of boost then you can create more even if you have a boost leak.. Im not saying you will build alot more but it should go past 5psi..
ilikebigbutts
Dec 20, 2006 05:46 PM
Luchini
Dec 11, 2005 04:06 AM
376R
Nov 13, 2005 05:49 PM
H22A EG6
Sep 27, 2005 11:50 AM
Meet07
Feb 3, 2004 10:45 PM
