wastegate sping question????
Old Oct 9, 2007 | 05:00 PM
high_octane's Avatar
Default wastegate sping question????
ok i am about to get my car tune an i have a 8 psi spring in it right now, how much psi can i get out of this spring??? i am trying to get around 28-29 psi, do i need to put a bigger spring in it to get my goal i want? Thank this is a fully built motor. thank!!
Old Oct 9, 2007 | 05:05 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: wastegate sping question???? (high_octane)
generally it is 2.5 times the spring.
so, 20 theoretically.
nasteboyii tamed my t3t67ho with a 10 psi spring and a 38mm gate to 30 psi.
it can be done, but on higher boost it may be prone to spiking or may fall off.
if it is a fully built motor, you can run a .8 .9 bar spring on pump. im running 33-34 psi on a .9 spring.
Old Oct 9, 2007 | 05:27 PM
so hows that 10 psi spring working for u???? cuzz i am runing a t4/t67 turbo on my built gsr.. dont want to fall out of boost..u think a 12 psi spring would be good eough? or should i just put a 14 psi spring in it.
Old Oct 10, 2007 | 02:54 AM
Mr. Badwrench
Default Re: (high_octane)
for consistency the 12 will be good, i have a 9. bar. 12-13 and it holds steady with the hondata boost comtrol at 33 psi up top.
Old Oct 10, 2007 | 05:15 AM
TiAL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by high_octane &raquo;</TD></TR><TR><TD CLASS="quote">ok i am about to get my car tune an i have a 8 psi spring in it right now, how much psi can i get out of this spring??? i am trying to get around 28-29 psi, do i need to put a bigger spring in it to get my goal i want? Thank this is a fully built motor. thank!!</TD></TR></TABLE>
it's 2x the spring pressure or a strert car,
you will want at least a 15psi spring
Old Oct 10, 2007 | 01:09 PM
boostedcivicsir hows that boost controler working for u on the s300 i just got one put in on my s300.
Old Oct 10, 2007 | 06:42 PM
Mr. Badwrench
i got an aem solenoid, i like it. ask tony1 about it. he recomended it to me as i had the s300 already. it can boost by gear and works well.
Old Oct 11, 2007 | 04:45 PM
so how much power u making and whats ur set up?
Old Oct 12, 2007 | 02:58 AM
Mr. Badwrench
Default Re: (boostedcivicsir)
http://forums.evans-tuning.com...=4713
t-powersi
Apr 29, 2007 08:02 AM
EJ8 GSR-T
Mar 14, 2007 12:17 PM
Lucky_Smurf
Sep 22, 2004 06:31 AM
Short Round
Nov 12, 2003 10:16 PM
X2BOARD
Jun 4, 2002 08:20 AM
