What Size Turbo would you guys recommend for my engine?
$4500 in a D series
ive tried searching but i havent found any decent information pertaining to it.
i have a d16y8 thats built. the head is completely rebuilt with oem replacement parts, the block has 9.5.1 75.5mm teflon coated Wiseco pistons and rings, Cometic turbo head gasket, ACL bearings, ARP rod and Head studs, its bored 20 over, Tuner toys I-beam rods.
i am currently running a log manifold with a 14b, my manifold has recently cracked so im going to get a new manifold and upgrade my turbo but im not sure on what size to get. thanks for the input...
Re: What Size Turbo would you guys recommend for my engine? (fresh pizza guy)
57 or 60 trim T3/T04E.
Very cost effective turbo for what sounds like are going to be your goals (300+WHP).
$4500 in a D series
Re: What Size Turbo would you guys recommend for my engine? (civic4u2nv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic4u2nv »</TD></TR><TR><TD CLASS="quote">my 2 cents up grade your manifold first. big dif from tube to log
good luck</TD></TR></TABLE>
yeah, im definatly getting a tubular manifold, i was just asking what size turbo would be the best choice...
hp goals and what the car will be used for will help someone suggest a turbo for you. list these things and someone will give you a better answer. GL.
i know my syntax sux, don't feel like typing correctly today.
$4500 in a D series
Re: What Size Turbo would you guys recommend for my engine? (KeyserSoze)
well its my daily driver, so i dont want anything thats gonna blow the **** up, but im looking to make about 300 whp, btw, im running 450cc injectors and not really trying to get new ones... so the most power i can with whats already there, as for the manifold im pretty sold on the CC-fab "chuck norris"....
Moderator
Re: What Size Turbo would you guys recommend for my engine? (Quad-Damage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damage »</TD></TR><TR><TD CLASS="quote">Sc50 would be a nice fit</TD></TR></TABLE>
So would a GT32 for the D-Series at that hp as well. Especially for the hp and response he's looking for.
Yeah upgrade that mani and then get ahold of a ported and clipped 16g. Theres a big diff. in cfm but not a huge change in lag time and cost is still cheaper than buying alot of
other co. turbos. Im getting ready to throw 1 on my 4x4toyota truck and have built a few kits around mitsu turbos.
$4500 in a D series
i dont want a turbo thats gonna be too large for my motor and not spool until almost redline... looking for something that will give me 300 whp and spool somewhat easily...
$4500 in a D series
Re: What Size Turbo would you guys recommend for my engine? (ccivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic »</TD></TR><TR><TD CLASS="quote">57 or 60 trim T3/T04E.
Very cost effective turbo for what sounds like are going to be your goals (300+WHP).</TD></TR></TABLE>
What A/R should i get.... say a 57 trim t3/t04E in a .48 or .63 a/r? i have no clue what that means anyways... im not a noob to boosting building cars... but damn turbos are complicated and im not trying to drop a wad on something without getting exactly what i want.
i got a 57 trim t3/t03e (.63) and i am looking to get around what you are getting (375+) and it should spool fully at 4700ish rpm
Anotherhatch
07-01-2003 05:14 PM
Apex i ITR
02-07-2003 07:46 AM
