what size TB?
Old Feb 26, 2008 | 06:44 PM
laocivic's Avatar
Default what size TB?
b16a eagles rod, cp pistons, gsr cams, skunk2 IM. that's about it for the setup.
how do i pick the right sized throttle body? is 68mm fine?
Old Feb 26, 2008 | 09:55 PM
Schister66's Avatar
Man U FTW
Its a waste to run a TB that's more than a few millimeters larger than your intercooler piping. I could reference my list of flow rates, but i dont care to type a lot right now.
Old Feb 26, 2008 | 10:37 PM
NA_B18C1's Avatar
edelbrock 75mm boy!!!
Old Feb 27, 2008 | 04:39 AM
Schister66's Avatar
Man U FTW
Default Re: (NA_B18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA_B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">edelbrock 75mm boy!!! </TD></TR></TABLE>
That may be a good suggestion, but the fact is, if its too large, it may actually hinder performance. The choice of what size throttle body is determined by the intercooler piping, flow rate of the turbo/engine, and intake manifold choice. If one was to go from a 2.5" intercooler pipe to a 75mm (2.95") throttle body, then back down to an intake manifold with a small plenum, the only thing you're going to see is turbulent flow through the throttle body. The best way is for the air to make a smooth transition from IC pipe, to TB, to IM, to engine...
Old Feb 27, 2008 | 05:37 AM
laocivic's Avatar
Default Re: (Schister66)
so i have 2.5 piping. what size is skunk2 1st gen IM?
Old Feb 27, 2008 | 07:07 AM
Schister66's Avatar
Man U FTW
Well if you're running 2.5" IC piping, then a throttle body in the 64-68mm range will work just fine for you without being too large.
roll8221
Mar 31, 2013 10:59 PM
CRXherbie91
Jul 28, 2010 04:48 PM
kte324
Feb 7, 2009 04:59 AM
Kid_SiR
Jan 6, 2008 06:27 PM
dunkd
Mar 5, 2005 01:12 AM
