Can you go too big on throttle size?
Thinking about doing a new intake and throttle body on my b18c1 build. Is the extra airflow needed with a forced induction setup? Will it be decreasing the pressure due to the added flow? Will I see any increase in performance or a decrease?
DO IT ON ALL FOURS
Re: Can you go too big on throttle size?
What power levels are we talking?
Yes you can go too big.
As long as the throttle body isn't a restriction (at least matches the Intercooler piping size) there isn't much of a need to go bigger on the average setup.
Decrease pressure? Please elaborate this mode of thinking...
Increase or Decrease power? Again, what is the setup you have and are thinking of going to?
This is WAY too vague of a thread.
Who is Mr Robot?
Like he said, normally it just needs to match the intercooler piping size.
Above 500hp 2.5" piping becomes a restriction and you need at least a 75mm tb.
But your question is way too vague for a specific answer
We need your full setup, power goals, the purpose of the car, etc before we can even begin to give specifics
Charge pipe sizing has a lot to do with internal air speed its not as simple as 500 its a restriction. I believe 2.5" will support u to .39mach or about 750cfm before there is a problem.
Who is Mr Robot?
This is very true, but I've seen numerous cases of high power cars going from 2.5 to 3" and making a lot more power before retuning.
B18c1, T3/T4 Turbo, .50 A/R Compressor, .63A/R Turbine, 3" Inlet Diameter & 2" Outlet Diameter, currently a stock intake and throttle-body, definately less than 500 HP....Not sure what other info you might need. I was looking at the skunk 2 pro manifolds with one of thier alpha throttle bodies (70mm port matched to pro manifold), but wasnt sure if bigger was necessarily better such as the 70mm versus the 68mm. Not sure what the mode of thinking was, just wasnt sure if the increase in throttle body bore would effect performance in a positive or negative way. what it boils down to is what size throttle body would be appropriate for the setup, if a change from stock is needed, and would i see significant enough power gains to make the upgrade...
-Hasport Mounts
-CP 81.5 Pistons
-Manley h-beam rods
-ACL bearings
-ARP main and head studs
-Supertech valves, springs, retainers, guides, seals
-Supertech block gaurd
-Clutchmasters 6 puck stage 4
-Aeromotive 340 fuel pump
-AEM fuel rail
-AEM fuel pressure regulator
-ID 725cc injectors
-OEM gaskets, oil pump, water pump
-hondata s300
-somewhere around 9.8:1 cr
-moroso 5.5quart pan
-Daily driver
-adding parts where i can
Hope this helps fill in any blanks...
all the help is appreciated...
-CP 81.5 Pistons
-Manley h-beam rods
-ACL bearings
-AEM fuel rail
-ID 725cc injectors
-hondata s300
-Daily driver
CRXherbie91
07-28-2010 04:48 PM
