nitrous question
Old Feb 14, 2006 | 05:17 PM
msbhvn_DC2's Avatar
Default nitrous question
i'm going to be running 40-60 shot of nitrous into my b18c1. do i need to upgrade any parts of my fuel system? also, do i need to retard the ignition timing or can i leave it right at zero?
Old Feb 14, 2006 | 06:17 PM
douspray's Avatar
Default Re: nitrous question (msbhvn_DC2)
i'd just retard the timing 1 to 3 degrees, and maybe look into a bigger fuel pump. thats what i did back when i spray'd my del sol.
Old Feb 14, 2006 | 06:18 PM
turbolshatch's Avatar
Default Re: nitrous question (douspray)
bump the fuel pressure a lil also
Old Feb 14, 2006 | 11:51 PM
msbhvn_DC2's Avatar
Default Re: nitrous question (turbolshatch)
will a fuel pump bring up the fuel pressure? or do i need to get a fuel pressure regulator also?
Old Feb 15, 2006 | 01:33 PM
msbhvn_DC2's Avatar
any more advice out there?
Old Feb 15, 2006 | 05:23 PM
BoredNStroked's Avatar
Do exactly as the manufacturer of the kit recomends. Some kits need additional timing retard and some use overly rich jetting to prevent detonation. If you dont know and understand what you are doing, dont do it. Nitrous is quick and cheap hp when done properly but very unforgiving when used otherwise.
Old Feb 15, 2006 | 05:59 PM
msbhvn_DC2's Avatar
Default Re: (BoredNStroked)
anymore nitrous users out there with some constructive advise?
Old Feb 15, 2006 | 06:38 PM
coneheadsracing's Avatar
Default Re: (msbhvn_DC2)
wet or dry kit? Wet is obviously safer. Is there anyone around there with a wide band, even a dyno shop would do. One tunning session wouldn't hurt. Best bet would be something that would retard your timing when you are using the spray vs just an overal retard of the timing, hurting you when you aren't spraying. Theres lots of ways to play. Just depends on what you want to do. Fuel pump and an FPR would be safe plays in my book. If you are going wet, this might not be needed then.
Old Feb 15, 2006 | 07:20 PM
msbhvn_DC2's Avatar
Default Re: (coneheadsracing)
i just picked up a used dry kit! i was wondering what is the smaller shot possible that i could go without even retard the timing, if it's possible?
Old Feb 15, 2006 | 07:26 PM
sc4dr's Avatar
Retard the timing a degree or two just to be safe, you really wont notice it when driving around town.
Old Feb 15, 2006 | 07:38 PM
msbhvn_DC2's Avatar
Default Re: (sc4dr)
is it possible to go as low as 30 shot jet?
Old Feb 15, 2006 | 07:58 PM
sc4dr's Avatar
yes
Old Feb 16, 2006 | 12:41 PM
msbhvn_DC2's Avatar
Default Re: (sc4dr)
any more advice out there guyz?
EfSedanLove
Jun 3, 2008 04:37 AM
nitroaccord105
Jul 18, 2007 12:32 PM
JDMlyfestyle
19
Jan 29, 2004 03:51 PM
willyboyK20
Mar 19, 2003 05:20 AM
