Head assembly is in need...
Old Dec 16, 2002 | 02:37 PM
tonylude94's Avatar
Default Head assembly is in need...
Hey whats up guys, i am looking for a head assembly with the head of course and competition valve springs and caps, rocker arms, cam caps and stage two cams. i am going to stick with stock valves and i have a h23. i need a reference for this.
if i were to go turbo what internals would i need to upgrade? and which brands are good quality?
thankx
Old Dec 16, 2002 | 06:32 PM
ViZ's Avatar
ViZ
Default Re: Head assembly is in need... (tonylude94)
well if you are going turbo you dont want regular stage 2 cams you want turbo cams, upgraded valvetrain is a good idea i would ceramic coat my valves if i where going turbo but i think internally with boost my main focus would be the block.. build it up to handle the boost .. lower the compression resleeve it and get forged pistons that type of thing.. a head job can cost you between 1-2 grand depending on who did it and if you are including cams and such... its a great upgrade but if you are going boost i would focus and save my money by building the block
Old Dec 16, 2002 | 06:36 PM
ViZ's Avatar
ViZ
Default Re: Head assembly is in need... (ViZ)
if you want to buy a head package i can get you a gude head package which includes port and polish cylinder head, racing valve grind, ported intake manifold, ported throttle body, header, camshafts and ecu for f22, h22 and h23 for
1495.00 and retail is 1682.45 core is 500
if you want something more custom to your setup i would recommend DPR ( dprracing.com ) they are a little bit more spendy and it takes a little time to have it done but i had my head done there and i am very happy with it
Old Dec 17, 2002 | 01:27 PM
tonylude94's Avatar
i going to be daily driven'
TougeCoupe
Sep 28, 2009 03:58 AM
stuie08
Nov 4, 2007 07:26 PM
00CIVICSITEIN
Apr 1, 2004 06:58 PM
Red Rocket
Feb 25, 2004 02:16 PM
dc2monkie
Sep 24, 2003 04:31 PM
