What psi on t25bb actuator
Old Oct 26, 2005 | 08:13 AM
Willie's Avatar
Default What psi on t25bb actuator
Im currently running a stock map sensor but the car seems to want to boost more than 11psi but cuts off. I also installed a mannual boost controller which doesnt seem to be working as i tried to get it to hold boost at 8psi. Its on a stock b16a2 if that helps.
Old Oct 26, 2005 | 08:32 AM
HiProfile's Avatar
Default Re: What psi on t25bb actuator (Willie)
Take a vacuum/pressure pump w/guage, hook it directly to the wastegate, pump, and see when the shaft moves. They tend to open slightly early, but the bleedoff keeps them shut long enough where it doesn't cause much lag. Otherwise...if it's installed, whatever level it holds at (before boost creep, if any) is the opening pressure.
Old Oct 26, 2005 | 08:39 AM
Willie's Avatar
I dont have a pressure pump as stupid as it sounds. Is there no other way/ do tou not have a rough idea of how much as it wants to go passed 11psi. The turbo is mabe by garret
Old Oct 26, 2005 | 09:08 AM
Soccerking3000's Avatar
Default Re: (Willie)
you have a stock map? it cant read past 11.3 psi or something like that and it might be causing you car to wig out, not exactly sure though
Old Oct 26, 2005 | 09:52 AM
Willie's Avatar
I know this, i just need to figure what spring is in the actuator. Can anyone figure it out without using a pressure pump
pamitar101
Sep 27, 2014 03:08 PM
ls1goat
Dec 2, 2013 07:53 AM
Hiboost 2.0
Apr 17, 2013 08:14 PM
GoHybrid
Mar 5, 2009 09:42 PM
budget
Jun 10, 2007 11:35 PM
