integra turbo 18g problem
Old Sep 27, 2014 | 06:26 AM
pamitar101's Avatar
Default integra turbo 18g problem
how much psi is on the stock wastegate ? 7 or 8 psi my car has an 18g greddy on it and im boosting at 12 to 14 psi on the stock wastegate with no boost controller somethings wrong ? im also getting what feels like boost cut at about 4500 rpms at WOT but if i only push the pedal half way and keep boost under 10 psi i can rev through to redline fine any ideas ?? and yes im running a 3 bar map sensor and my ecu is chipped for it i was thinking a bad wastegate actuator......i couldent find any boost leaks either
Old Sep 27, 2014 | 03:08 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: integra turbo 18g problem
Are you sure the kit has the original actuator? The Greddy actuator won't hold pressure much past 14psi so a lot of people use a higher base pressure actuator.
tyoung
Jul 18, 2008 02:06 AM
Drew Peacock
Sep 5, 2004 10:36 PM
vangc6780
Aug 14, 2004 11:18 PM
maddog20
Aug 4, 2003 03:07 AM
Kevin
Nov 18, 2002 10:05 AM
