What oil preassure to turbo?
Well I think I might have a problem, My car started smoking yesterday and I found oil in the charge pipe, so I think it is the turbo. Then I realized I forgot an oil pressure regulator for it. I checked and with 60psi at idle, I think I blew the seals. What pressure should it be at?
I have a Garret T25 with a direct feed oil hook-up (no banjo bolts).
-Dustin
-Dustin
Re: What oil preassure to turbo? (Autocratic_1st_Gen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autocratic_1st_Gen »</TD></TR><TR><TD CLASS="quote">Well I think I might have a problem, My car started smoking yesterday and I found oil in the charge pipe, so I think it is the turbo. Then I realized I forgot an oil pressure regulator for it. I checked and with 60psi at idle, I think I blew the seals. What pressure should it be at?
-Dustin</TD></TR></TABLE>
banjo bolts ******* suck. can't get any replacements!! GRRR. If it weren't for those damn bolts, my setup would be done.
Re: What oil preassure to turbo? (MachAF)
I think for the oil feed you can use either a 1/8 or 1/4 compression thread, just maker er real tight! and use thread sealer. Thats what I have. For the water lines I will be trying either 1/4 or 3/8 pipe thread with a similar dose torque and sealant.
-Dustin
-Dustin
