What materal to use to make wastegate arm ACT. adaptor
My Compressor housing is going to need rotated, and I've tried to find anyway possible to get the stock wastegate arm to line up with the turbine housing, but its not going to happen.
So I need a wastegate arm adaptor. Something that can attach to the turbos factory wastegate arm and then turn/or adjust to the new placement of the turbine housing vs the compressor housing without benting or breaking.
HF manifold TDo4L-13G turbo.
the turbo outlet is facing directly into the radator ( not enough clearence ), so i have to rotate it appox. 90 degrees to face straight up.
redlseg
07-20-2005 10:31 PM
