b16a2 intake manifold question
Old Aug 18, 2003 | 12:04 PM
BLACKLUDE97's Avatar
Default b16a2 intake manifold question
i had a question about which intake manifold it was that bolts right on to a b16a2. was it a gsr manifold or a type r manifold? someone help me out.
Old Aug 18, 2003 | 12:10 PM
black92si's Avatar
Default Re: b16a2 intake manifold question (BLACKLUDE97)
not a gsr
Old Aug 18, 2003 | 12:34 PM
turbo Si's Avatar
Default Re: b16a2 intake manifold question (black92si)
I am almost sure that the type R is compatable. The B16A2 and the type R utilize alot of the same part numbers as well.
Old Aug 18, 2003 | 12:37 PM
yeah... thats what i thought. thanks!!
Old Aug 18, 2003 | 12:54 PM
VTEC-DA's Avatar
Default Re: (BLACKLUDE97)
B16A, B16B, B17A and B18C5 all share the same bolt patter as far as the intake manifold.
Old Aug 18, 2003 | 09:19 PM
T4eg's Avatar
Default Re: (VTEC-DA)
the type-r is what your looking for. They will bolt on just the cooling passage is different. (someone correct me if im wrong on the last part)
Old Aug 18, 2003 | 11:39 PM
LiLOtaku's Avatar
Default Re: (BlueHatch00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueHatch00 &raquo;</TD></TR><TR><TD CLASS="quote">the type-r is what your looking for. They will bolt on just the cooling passage is different. (someone correct me if im wrong on the last part)</TD></TR></TABLE>
You can use the TypeR intake manifold.
yes, there is a coolant passage that you have to block off if you are going to be putting it on your B16. Its going to be on cylinder #4 runner and you can prolly just get yourself a vacuum niple, stick it on and then tighten it on with a small hose clamp. If you are going to be running a turbo with water cooling, you can use this passage to feed the turbo and then tap back into the throttle body water line.
Old Aug 18, 2003 | 11:45 PM
The sweed's Avatar
The only problem I had was that the Idle air control valve hade one diffrent bolt.. But I just welded a pice of aluminum and threded a hole in it so i could attach the valva correctly.. That was for euro spec ITR and b16a2 anyway but Ithink it´s the same on US models..
Old Aug 18, 2003 | 11:58 PM
LiLOtaku's Avatar
Default Re: b16a2 intake manifold question (The sweed)
If your motor is from a 99 Civic Si, your IACV will hook directly up to the TypeR one.
ImportsCRX
Dec 21, 2004 09:25 AM
Rickcrx
Dec 11, 2004 11:08 AM
12.47crx
Sep 9, 2004 12:37 PM
SpoonMan
Dec 16, 2002 08:54 PM
2000GSRT
Aug 2, 2002 09:33 AM
