What Map Sensor For PowerFC?
Old Nov 5, 2007 | 08:17 PM
integlspwr2k's Avatar
Default What Map Sensor For PowerFC?
I wanted to run a 3bar map sensor on my power FC, anyone know which one will work and how to get it to work.
Thanks in advance?
Old Nov 10, 2007 | 05:20 PM
TheShodan's Avatar
Moderator
Default Re: What Map Sensor For PowerFC? (integlspwr2k)
You need to be able to use the "Boost KIT" that includes the harness and 3 bar pressure sensor that hooks directly into the power FC (WHITE PLUG). There are a couple of people in Australia that did a GM 3 bar map sensor, but it threw off the maps that the Power FC uses for voltage to make sure it has the right amount of pressure. You'll still need either FC Datalogit, or a Power EXcel tuner to work with it. Simply trying to do it from the commander for a BOOSTED application takes darn near 10 hours. I've tried it, so believe me.
Old Nov 10, 2007 | 06:26 PM
tony1's Avatar
Default Re: What Map Sensor For PowerFC? (TheShodan)
The apex pressure sensor is plug and play, but if you change the calibration for the pressure sensor, you can also use a GM 3 bar.
Old Nov 10, 2007 | 07:38 PM
TheShodan's Avatar
Moderator
Default Re: What Map Sensor For PowerFC? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">The apex pressure sensor is plug and play, but if you change the calibration for the pressure sensor, you can also use a GM 3 bar. </TD></TR></TABLE>
Very True. The wiring can be tedious, to go into the harness, but it can be done.
Old Nov 10, 2007 | 07:42 PM
tony1's Avatar
You buy the pressure sensor harness from Apex and wire the 3 wires into the GM sensor, not too tedious really.
Old Nov 11, 2007 | 07:12 AM
I jsut bought the harness and map sensor from the same guy i purchased the PFC from. Costed $165 but it was here already, and no need to mess around with it in the tuning software.
Old Nov 11, 2007 | 03:23 PM
TheShodan's Avatar
Moderator
cool. Plug and go. No muss, no fuss.
Old Nov 11, 2007 | 05:59 PM
anyone know if changes need to be made in datalogit for it to read the new map sensor?
Old Nov 11, 2007 | 06:08 PM
TheShodan's Avatar
Moderator
From what I remember, it should be able to have the right calibration for the map sensor once it sees that it is plugged in. Remember, DO NOT REMOVE YOUR OEM MAP SENSOR. The power FC works with Both sensors together, not like a GM 3 bar, where it takes over all of the readings. Once the Map sees boost, it will see the other sensor and work accordingly. That's why I stated to just plug and play, there is no calibration needed.
The only thing different that you will notice is that your check engine light will illuminate after 11psi, even with the sensor. Ignore it, it is just a code that the Power FC engineers forgot to eliminate when adding the pressure sensor. I've run it for 4 years, its not a problem at all.
Legion
Apr 14, 2007 10:47 AM
abmerop18
May 28, 2006 07:45 PM
used2baracer
May 31, 2005 10:08 AM
vti444
Apr 14, 2005 08:01 PM
joeyitr309
Oct 21, 2001 12:04 PM
