turbo kit where i can keep a/c?
I tried searching but makes it hard when a/c won't turn up any results. is there a turbo kit i can use on a gsr-swapped sol that lets me keep my AC and PS? or should I look at supercharging instead?
Re: turbo kit where i can keep a/c?
if you researched more you would have found that both full-race and peakboost make kits to keep one or the other or even both depending what size turbo and manifold you run. most other companies make similar products. do more research.
What he's saying is that the only thing that allows you to keep a/c or p/s is where the manifold sits the turbo. As long as the turbo is out of the way, the rest is just working around that stuff. A log manifold with the flange strategically placed is your best bet.
There are several manifolds capable of running ac and ps. Ram horns, logs, and cast are the norms. If you're on a budget just get a cast manifolds they hold up just find, the hardest part about keeping AC is making a custom DP unless you want to spend hundreds and buy one off the self.
look into AFI arizona forced induction or you can contact one of our dealers at www.speed-theory.com
integra3586
06-14-2006 05:22 PM
