turbo manifold
Old May 10, 2009 | 03:19 PM
2000siturboR's Avatar
Default turbo manifold
im looking for a turbo exhaust manifold for a b16 that is ac compatiable. right now my turbo setup consists of the greddy turbo kit. with the td05 18g turbo. im ditching that kit for a garrett gt28rs turbo (chose this because of the fast spooling and would like to keep my setup internal wastegate). im trying to find a place that sells a turbo exhaust manfold for this turbo that is ac compatable. i checked out inline pro but really didnt find nothing. and one more question. the gt28rs turbo does that call for a t3 style exhaust flange.
any help i would appreciate it. dont know to much about turbos just started getting into them.
Old Jun 4, 2009 | 06:46 AM
b-ready's Avatar
Default Re: turbo manifold
The garrett turbo you are wanting to use is a t28. You can buy one from Eldebrock it will work and you will be able to keep you ac. Also the greddy manifold on the kit you have will also work. I am usesing the eldebrock mainfold on a greddy 18g turbo so I know it will work.
Old Jun 4, 2009 | 07:54 AM
TheShodan's Avatar
Moderator
The GT28RS is not the same turbocharger as the T28 that is used in the Edlebrock kit. The GT28RS will fit both in a T3 configuration and a T25 flanged configuration. Since you are staying internally gated, you would need to keep the T25 flanged system. The drain system from your GReddy kit needs to be altered a bit, as it is different. Even your GReddy manifold is more effective.
You do realize in your quest for more power, that the 18G is a bit bigger than the GT2860RS Disco potato, using only an ever so slightly larger turbine wheel, correct? I'm assuming that your quest for more power is the motive behind changing turbochargers? If that is the case, the GT3071R is a much better option that what you're going to .
Here's the size comparison
GReddy 18G
Compressor
Inducer 50.5mm
Exducer 68mm
Turbine
Wheel diameter - 56mm
Inducer - 49mm
Old Jun 4, 2009 | 08:00 AM
TheShodan's Avatar
Moderator
GT2860RS
Compressor
Inducer 47.2mm
Exducer 60mm
Turbine
Wheel Diameter 53.8mm
Inducer - 61.7mm
CrX1988Zc
Mid-Atlantic (Sales)
Feb 5, 2009 01:00 PM
CrX1988Zc
Feb 5, 2009 12:59 PM
DvD3
Apr 26, 2005 04:01 PM
AdvanTech
Oct 29, 2004 06:39 AM
SYDNEYSIDER
Dec 11, 2001 10:11 AM
