What kind of compressor cover is this?
Old Mar 7, 2004 | 06:39 PM
lazerus's Avatar
Default What kind of compressor cover is this?
http://cgi.ebay.com/ebaymotors...39343
Thanks,
Brad
Old Mar 7, 2004 | 10:04 PM
calib17a's Avatar
Default Re: What kind of compressor cover is this? (lazerus)
T04E style compressor housing with 2.75 - 3.00 inlet and 2.00" outlet. Very Good response turbo for 4 Cyl applications. This turbo has a flow capacity of about 500HP. This turbo would be the same as HKS GT3037. The GT30R turbine housings with 4 bolt exit are made out of ductile Ni-Resist iron (has a nickel content of about 38%). This material is much better at withstanding high exhaust gas temperatures than regular cast iron. The turbine wheel is inconnel 713 and is good for up to 1700 degrees farenheit. The wheel can sustain longer operation at higher temperature but not for long periods of time.
Old Mar 7, 2004 | 10:20 PM
ninesecteg's Avatar
they are called a shrouded compressor cover. they prevent compressor surge i believe.
Old Mar 8, 2004 | 09:04 AM
SiRkid's Avatar
Default Re: What kind of compressor cover is this? (ninesecteg)
that design improves efficiency a little bit!(also makes the turbo scream )
Old Mar 8, 2004 | 09:20 PM
lazerus's Avatar
Default Re: What kind of compressor cover is this? (SiRkid)
yeah, thats what i want
Old Mar 8, 2004 | 10:14 PM
Tony the Tiger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid &raquo;</TD></TR><TR><TD CLASS="quote">that design improves efficiency a little bit!(also makes the turbo scream )</TD></TR></TABLE>
Nope.
It's an anti-surge housing designed to reduce or sometimes eliminate compressor surge. The byproduct is a high pitched sound, which to some people sounds good. It actually hinders efficiency by a bit, but its benefits outweighs the disadvantages.
Old Mar 8, 2004 | 10:26 PM
lazerus's Avatar
Default Re: What kind of compressor cover is this? (Tony the Tiger)
neat. im gonna get one
Old Mar 8, 2004 | 11:10 PM
Arturbo's Avatar
Better than steak
25 Year Member
I am using the ported shroud on my car and so is the new turbo on the Laskey's Race Crx. Basically what it does is it moves the compressor map away from the surge line and flow more but not more effcient.
BTW, I have the very 1st of these for the GT35E from Precision. There are few people who have these and I'll have pics later.
art
Old Mar 8, 2004 | 11:11 PM
Arturbo's Avatar
Better than steak
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">Nope.
It's an anti-surge housing designed to reduce or sometimes eliminate compressor surge. The byproduct is a high pitched sound, which to some people sounds good. It actually hinders efficiency by a bit, but its benefits outweighs the disadvantages.</TD></TR></TABLE>
he hit it right on the nose.
Old Mar 8, 2004 | 11:12 PM
CheezeFrog's Avatar
Default Re: What kind of compressor cover is this? (Arturbo)
Ok I'm turbo illiterate... is the GT35E what I just got??
Old Mar 9, 2004 | 12:18 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: What kind of compressor cover is this? (CheezeFrog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CheezeFrog &raquo;</TD></TR><TR><TD CLASS="quote">Ok I'm turbo illiterate... is the GT35E what I just got??</TD></TR></TABLE>
NO!! We wont talk about your turbo.
93grayeg
Feb 18, 2013 10:12 PM
Natural Aspirations
Feb 19, 2008 11:55 AM
jetlude
Oct 10, 2007 02:14 PM
raene
Apr 6, 2005 10:07 AM
00b18b
Nov 13, 2001 02:54 PM
