what IAT sensor to use?
Old Dec 17, 2008 | 06:24 AM
irishflame27's Avatar
Default what IAT sensor to use?
just curious what IAT sensors you guys are using on your force inducted setups, i will have a b16 w/ s300 and curious if stock is okay or aftermarket is needed
Old Dec 17, 2008 | 06:46 AM
NIGHTRIDER27's Avatar
stock. i welded a bung in to my charge pipe and found a threaded fitting for it that was like a reducer for pluming and stuck the stock sensor in there and used epoxy to seal it works great.
Old Dec 17, 2008 | 06:50 AM
boostedcivicsir's Avatar
Mr. Badwrench
stock for now, but gm sensor is on my to do list.
Old Dec 17, 2008 | 07:21 AM
RedneckRicer's Avatar
have Neptune/Hondata ect come up with a scalar for the GM IAT. i know the stock one reads slow
Old Dec 17, 2008 | 10:48 AM
slowwhitehatch's Avatar
which gm IAT sensor does anyone knows the part# to it and could it be used on the AEM ecu.
Old Dec 17, 2008 | 10:56 AM
redboost10's Avatar
contact tony for the gm iat sensor. he will also tell you why he recommends using that one over the honda one, kinda crazy to hear
Old Dec 17, 2008 | 05:43 PM
i demand that tony comes in here and explains!!! lol
Old Dec 18, 2008 | 07:08 AM
i would like to hear this also
Old Dec 18, 2008 | 07:46 AM
tony1's Avatar
We actually have some new sensors that are similar to the GM, and the same cal as the GM, but slightly quicker response. They are an M14 x 1.5 thread, but we also have threaded aluminum weld on bungs for them.
Night and day difference between these and the Honda sensor. There's right about a 12 second delay between the two on the drag strip. Obviously 12 seconds late on your air temp comps doesn't do you much good.
Not sure how far off the cal will be running one on an S300 with a Honda temp sensor cal, but the cal being off won't be a big deal if you tune around it. The temp changing quickly is way more important than the actual number being correct. I think it's no more than 30 deg or so off though.
Old Dec 18, 2008 | 12:44 PM
drewbie57's Avatar
Get a bung and a threaded IAT fitting from a CRV. Easy peasy.
Old Dec 18, 2008 | 11:13 PM
nowtype's Avatar
Do a search under my name for some ramblings on GM IAT sensor vs Honda OEM. I did some math on the calibrations if I remember correctly.
Old Dec 19, 2008 | 01:55 AM
DaveF's Avatar
Tony, does the new sensor you have, use the same connector as the gm sensor ?
Old Dec 19, 2008 | 07:09 AM
redboost10's Avatar
and the same thread?
Old Dec 19, 2008 | 09:21 AM
96 GSR-T's Avatar
No, the GM/AEM uses resisted voltage, I have this sensor and I couldnt get it to work with the inputs in NepTune, I was quite upset....lol
nowtype I have a list of the temperatures and resistance values for the GM sensor, they problem for me was converting those figures into 0-5v figures, so I gave up on it.
Old Dec 19, 2008 | 09:34 AM
well that sucks. hopefully someone figures it out cause im not smart enough too..lol
2009HondaAccord
Feb 18, 2018 06:41 PM
SPOOLINmatt
Engine Management and Tuning
Dec 25, 2009 06:06 AM
riddlinkid1986
Aug 10, 2008 04:43 PM
Del_Slowest
Jul 18, 2004 05:53 PM
c1hatch
Aug 15, 2002 09:10 AM
