GM knock sensor???
Old Aug 15, 2002 | 07:28 AM
c1hatch's Avatar
Default GM knock sensor???
Has anyone adapted a GM knock sensor on instead of the OEM one. I was just wondering, cause the honda sensor cost about 3 times as much as a GM one.
& what knid of adapter would i use?
thanks
Old Aug 15, 2002 | 07:57 AM
DirtyLude's Avatar
Default Re: GM knock sensor??? (c1hatch)
The GM sensor isn't as sensitive as the Honda sensor. I wouldn't try using the GM sensor with the stock ECU just because it should dull the knock sensing abilities of the stock ECU. When I was thinking of replacing my stock sensor with the GM sensor that came with my J&S safeguard I couldn't find any adapter. I was thinking of just getting a larger adapter and taping out the sensor port for it.
Old Aug 15, 2002 | 09:06 AM
c1hatch's Avatar
Default Re: GM knock sensor??? (DirtyLude)
what do you mean by dull the capabitities. I wouldnt care for it beng less sensitive for detecting knock, just as long as it doesnt throw a CEL. Is there a down side to this?
Old Aug 15, 2002 | 09:10 AM
Smashback's Avatar
Uh, yeah like it starts knocking and the GM sensor doesn't pick up on it in time for the ECU to compensate and kaboom.
Other than that, I don't see any problems!
shadykit
18
Mar 14, 2005 12:51 PM
SC94DB8
Oct 22, 2002 11:16 AM
dustin
Sep 26, 2002 07:20 PM
