What do you think of this setup on my b16???
Old Oct 5, 2004 | 08:20 PM
KiNG $h!t's Avatar
Default What do you think of this setup on my b16???
IHI RHB5 Turbo + 1st gen crushed BOV (For more boost) + 1st gen SMIC do you think this setup is capable of squeezign low 200'swhp on a fmu and rev hard mani.
the b16 is completely stock just has a gsr tb. Oh yea and it is a jdm b16 so the compression is a tad bit higher.
Old Oct 6, 2004 | 09:16 AM
KiNG $h!t's Avatar
up
Old Oct 6, 2004 | 09:18 AM
m R g S r's Avatar
Default Re: What do you think of this setup on my b16??? (this guy 2fast)
You should be fine with that setup for 200whp.
Old Oct 6, 2004 | 09:23 AM
KiNG $h!t's Avatar
what fmu would you recommend to use?
Old Oct 6, 2004 | 09:25 AM
MIKES's Avatar
Default Re: What do you think of this setup on my b16??? (m R g S r)
You might aswell stay N/A if 200whp is your goal. Get a bigger turbo and make some decent power. You don't have to go crazy. Just get a 14 or 18G turbo and run 10psi and make 240 to 260 at the wheels.
Old Oct 6, 2004 | 09:31 AM
KiNG $h!t's Avatar
i will upgrade down the rode right now im just going to use this. I got everythign for dirt cheap so i wil be happy with any improvement over my stock b16.
Oh and i have a chipped ecu on my b16 right now will i need to get a stock ecu? or will the chipped one be fine?
Old Oct 6, 2004 | 10:03 AM
B6tPoweredMx3's Avatar
Default Re: (RedNeckTruckDriver)
now which ihi turbo charger do you have ?
Just a little info on upgrading the ihi rhb52 turbos in the future for you.
The vj-14 was on the 1.6 litre 323/capri's. Turbo maxes out at 15 psi with 7.9-1 compression.
The vj-11 was on the 2.2 litre probe/mx6 which i belive made 12-14 psi (i believe) on these motors, but the vj-11/vj-14 hybrid on the 323 or capri is said to do 19 psi till redline. (6300 rpms)
the vj-16 is on the Thunderbird and makes a good amount of power and you can hybridize this with the vj-14 ( biggest intake cartridge you can put on a 14).
So which ihi do you have? it will say next to the ihi rhb52_____
Old Oct 6, 2004 | 10:22 AM
KiNG $h!t's Avatar
its the 2.2lt probe turbo
Old Oct 6, 2004 | 11:17 AM
Default Re: (this guy 2fast)
ok its set to 7.3 psi, but because of the Pos wastegate it spikes to around 9-10 at 3k rpms. while you have it out i would have someone port your wastegate.
Old Oct 6, 2004 | 11:30 AM
m R g S r's Avatar
If it spikes to 10psi, that sounds perfect. That should get you 200ish whp. . .
Old Oct 6, 2004 | 11:45 AM
KiNG $h!t's Avatar
what will porting the wastegate do?
Old Oct 6, 2004 | 11:53 AM
eliminate the boost creep/spike. if you want to run high boost just get a boost controller.
Old Oct 6, 2004 | 11:56 AM
KiNG $h!t's Avatar
how safe will this setup be for a daily driven ride?
Old Oct 6, 2004 | 12:27 PM
hmm what are you going to do with your timing etc. you should also look into a wideband o2 sensor, egt gauge etc so you can monitor things. Daily driven maybe with some tuning.What are you doing about your injectors? you should really look into an apexi unit/piggy back fuel computer.
Old Oct 6, 2004 | 03:28 PM
KiNG $h!t's Avatar
well i was trying to do a budget build. Thats y i was trying to stay fmu for now. I guess i mine as well atleast use hondata though along with some dsm injectors too huh?
what would you recommend to do with timing for a daily driver?
Old Oct 6, 2004 | 03:30 PM
Oyvind Ryeng's Avatar
People seems to think that the turbokit is more important that the management? No chain is stronger than it's weakest link, and ruining a perfectly fine B16 with detonation because of "savings" in the management-section is not the smartest thing one could do. The tuning is the key to a happy engine, and an adrenaline-filled driver.
Old Oct 6, 2004 | 03:40 PM
91civicDXdude's Avatar
Default Re: (Oyvind Ryeng)
rhb5
its a pile of poo too small for any use
Old Oct 6, 2004 | 04:53 PM
Jeffescortlx's Avatar
Default Re: (91civicDXdude)
Yeah there small, and dont make much power. But I used one from 1984, original unrebuilt and it worked fine even after I replaced it for a larger one.
b16ajdmrex
May 23, 2009 09:20 AM
lukerc45
Nov 23, 2007 09:45 PM
American.Graffiti
Aug 4, 2006 12:33 PM
navz121
Sep 8, 2004 07:46 PM
iwouldHITit
38
Dec 29, 2002 12:09 PM
