350hp on t3 super 60?
i have a vitara piston setup with eagles rods and all that good stuff i have everything i need all i need is a turbo i saw a super 60 on vsracing.com they have a .48ar and a .63ar wich one will go good for my setup and will i be able to make 350 hp with it ?
Re: 350hp on t3 super 60? (Manny86)
you will not be close to 350hp with that setup at all
that turbo is only rated at max i would push it is about 315-320 you can get out of it.
if you trying to make 350 i would recoomend 50trim t3./t04e .48ar
Re: 350hp on t3 super 60? (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">you will not be close to 350hp with that setup at all
Agreed, but I'd go with a T3/T4 50 trim .63 A/R
Re: (Manny86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manny86 »</TD></TR><TR><TD CLASS="quote">will 300whp be enough to go 12's at the track ? if i get traction .</TD></TR></TABLE>
Yes, you can get in the 12s with less than 300whp with a good overall setup.
Re: (Manny86)
the car i tuned to 301whp went 12.2 on 225 drag radials in a semi gutted ek coupe...and yes 450's were damn near maxed.
