What to do immediately when engine overheats?
Old May 17, 2002 | 04:00 PM
  #26
PrecisionH23a's Avatar
Default Re: What to do immediately when engine overheats? (88CRXHybrid)
yeah that gas. I think you check it with a special tool. You suck up some coolant in a tube with these ***** in it. If the ***** float or sink tells you whether you need to change out the fluid or not AKA carbon monoxides in the coolant or not.
whoops... i forgot to mention that in my post. this tool is available at NAPA.
Old May 19, 2002 | 11:47 AM
  #27
austrian type-R's Avatar
Default Re: What to do immediately when engine overheats? (dustin)
How can the motor get hotter when the engine is turned off ?
Heat = thermal energy. Turn the motor off and the temperature will go down.
The coolant does'nt circulate anymore, cause the water pump is not working. Therefore the heat can not transported which is still *in the engine*
Old May 19, 2002 | 11:50 AM
  #28
dustin's Avatar
Default Re: What to do immediately when engine overheats? (austrian type-R)
There won't be any extra heat though... just the heat will not be spread through the cooling system when the motor is turned off. If there is /no/ coolant in the motor, the best thing you can do is shut the car off and let it cool down.
Old May 19, 2002 | 12:08 PM
  #29
Okay, the engine will not getting hotter like it is, but will the engine cool quicker down when it is running and the water pump pumps the coolant thru the radiator? I think it does.
Old May 19, 2002 | 12:12 PM
  #30
dustin's Avatar
hehe of course it will, if it's not overheating
Old May 19, 2002 | 12:13 PM
  #31
sgT's Avatar
sgT
If its overheating due to mechanical failure such as blown HG etc, then keeping
it running will just make it overheat more.
GBRacing
34
Feb 3, 2010 12:03 AM
acurastreetracer
Mar 7, 2006 12:39 PM
CC2
Feb 3, 2006 03:14 PM
aeon
Apr 12, 2004 05:40 PM
blah13
Apr 16, 2003 09:45 AM
