Engine is really hot, is this normal?
Old Apr 11, 2004 | 10:36 PM
aeon's Avatar
Default Engine is really hot, is this normal?
Well lately, I've been checking out my engine after i drive it a little and it gets really hot in there. everything is freaking hot, even all of the hose's. Yesterday, i cleaned my engine with some engine degreaser and after i cleaned it, i started up my engine while i was drying off some of the water and accidently hit my headers and that thing burnt my finger. i barely touched it and that suckers was hot. The engine was on for less then 5 minutes. I just wanted to know if this was normal. the temp gauge on my car shows that everything is normal, no overheating or anything.
Old Apr 11, 2004 | 10:44 PM
Integra4lyfe's Avatar
Default Re: Engine is really hot, is this normal? (aeon)
yes engines get warm ESPECIALLY headers. Never touch a header that's been on for a few minutes.
Old Apr 11, 2004 | 11:10 PM
Kusai.Nihonjin.Desu's Avatar
Default Re: Engine is really hot, is this normal? (Integra4lyfe)
Your car should be fine, unless your gauges arent working. I'd double check the oil/coolant and call it a day.
Old Apr 11, 2004 | 11:12 PM
xplanetearth420x's Avatar
dude if you had your car on for 5 seconds and you touched your header it will dive you sencond degrre burns that is very normal what do you expect it to be cold?
Old Apr 11, 2004 | 11:49 PM
aeon's Avatar
Default Re: Engine is really hot, is this normal? (xplanetearth420x)
I was only asking, no need to take it to the ***. I just haven't noticed this before so i just wanted to make sure. Not like i intentionally freaking touched the headers. like i said, i was drying off some parts and accidently touched the header.
Old Apr 11, 2004 | 11:57 PM
PlastikOwl
Guest
Posts: n/a
once bumped my header with bare skin for less than half a second... nothing happened immediately...but sat there and watched while blisters formed after 1-2 seconds.
Old Apr 12, 2004 | 12:02 AM
svtec's Avatar
L D E S
Default Re: Engine is really hot, is this normal? (PlastikOwl)
i burned my big *** nose on my header when i was putting on my high flow cat.
i looked like rudolphstein the red nosed raindear.
Old Apr 12, 2004 | 01:02 AM
Smeeg Heed's Avatar
Default Re: Engine is really hot, is this normal? (svtec)
you realize that your engine has hundreds of controlled explosions going on inside it every second right?
Old Apr 12, 2004 | 05:34 PM
IVI's Avatar
IVI
yes engines get hot. its normal.
Old Apr 12, 2004 | 05:40 PM
IN VTEC's Avatar
EGT's are typically around 400 deg Celcius at idle after the EGT's get up to temp. 400 deg C is roughly 750 deg F, and the manifold absorbs a lot of that heat.
tbonez
Honda Civic (2006 - 2015)
Dec 7, 2010 09:44 AM
litterbox
Mar 16, 2009 06:50 AM
evans
Feb 10, 2007 01:08 PM
gimme789
Mar 12, 2006 06:51 PM
ScubaStevo80
Jan 2, 2005 11:17 AM
