What could be a reason my bov is not working....
Old Mar 20, 2004 | 06:20 AM
FOrSfEd's Avatar
Default What could be a reason my bov is not working....
i have a greddy type s bov. It's hooked up correctly to the nipple at the top and seems to have a good vaccum source being my vaccum manifold. Screw is turned all the way soft plus I've had it all the way hard. Still nothing. I know this thing worked when I got it, but then I took the adjusting screw all the way out and put it back in. And since then the bov has not worked. Any suggestions.
Old Mar 20, 2004 | 06:33 AM
MiraiZ's Avatar
Default Re: What could be a reason my bov is not working.... (FOrSfEd)
can you push the piston up an down by hand? maybe its stuck?
Old Mar 20, 2004 | 06:37 AM
FOrSfEd's Avatar
Default Re: What could be a reason my bov is not working.... (MiraiZ)
Yeah when I take it off I can push it and it moves
Old Mar 20, 2004 | 06:54 AM
MiraiZ's Avatar
hmm...are you sure you have the vacuum source plugged into the right place...I know that some BOVs have two nipples...
Old Mar 20, 2004 | 06:57 AM
FOrSfEd's Avatar
Yeah it has one on the lower back side and one on the front upper side. Everyone says it the one on the front side that it plugs in too. I guess what I might do is hook it up to another source for the vaccum and see if it does anything. But when it's hooked up and the car is running and I disconnect the vaccum source from the bov the car almost cust off so it seems that it's getting the amount of vaccum.
Old Mar 20, 2004 | 07:01 AM
MiraiZ's Avatar
BOVs are really simple devices...either it works or it doesn't, and it sound as if yours is ok...just try the other port or maybe another source...
Old Mar 20, 2004 | 07:04 AM
FOrSfEd's Avatar
Thanks man for your help I'll see if another port works better.
Old Mar 20, 2004 | 10:44 AM
shotty's Avatar
Make sure the vacuum source you are hooked into is between the throttle body and the engine. Not before the throttle.....
k20powered
May 10, 2010 11:37 AM
Turbo D17
Dec 12, 2004 12:06 PM
iwhichisme
Jun 14, 2004 08:05 PM
FOrSfEd
Mar 28, 2004 09:16 AM
wickedxboi
May 21, 2003 08:33 PM
