My Bov does not work.. Need Help
Old Mar 27, 2004 | 09:27 AM
FOrSfEd's Avatar
Default My Bov does not work.. Need Help
I' ve done everything I can think of to get this to work and yet it still does not. I've adjusted it to hard and too soft, I have even taken it apart and put it back together still nothing. All I get it compressor surge. I know iut worked at one time then I took the adjusting screw all the way out and put it back in and since then it has not worked. Maybe I'm not adjusting it right. Can anyone help me. Btw it is a greddy type s bov. I know the vaccum line that is feeding it is right cause when I take it off the bov with the car running the car almost custs off.
Old Mar 27, 2004 | 09:28 AM
FOrSfEd's Avatar
Default Re: My Bov does not work.. Need Help (FOrSfEd)
up
Old Mar 27, 2004 | 03:41 PM
iiilgsrlll's Avatar
You have the vacuum hose hooked up to the nipple pointing straight out and not the diagonal one right?
Old Mar 27, 2004 | 03:43 PM
FOrSfEd's Avatar
Default Re: My Bov does not work.. Need Help (iiilgsrlll)
yeah i do. Thanks
Old Mar 27, 2004 | 03:49 PM
iiilgsrlll's Avatar
If you take the BOV off the flange does the valve open at idle?
Old Mar 27, 2004 | 07:17 PM
Ls-Rturbo's Avatar
just say fu@k it and by mine
Old Mar 27, 2004 | 07:29 PM
m R g S r's Avatar
Default Re: My Bov does not work.. Need Help (bl18t)
Are there two nipples on the BOV? If so, try the other (If you haven't already done that)
Old Mar 28, 2004 | 05:05 AM
FOrSfEd's Avatar
Default Re: My Bov does not work.. Need Help (m R g S r)
yeah there are two, I'll try the other and see what it does
Old Mar 28, 2004 | 09:16 AM
FOrSfEd's Avatar
i tried the other nipple and it did worse. So i still can't figure out what is wrong
boosted_duece
Nov 23, 2005 09:29 PM
LVB18Civic
Mar 3, 2005 09:17 PM
Blanket Jackson
Nov 28, 2004 12:18 PM
FOrSfEd
Mar 20, 2004 10:44 AM
wickedxboi
May 21, 2003 08:33 PM
