Compressor Surge!
Old May 9, 2010 | 05:09 PM
k20powered's Avatar
Default Compressor Surge!
if im runnin 10psi do i need to run a BOV ?...right now my BOV for some reason does not open up and doesnt blow off and i did all the adjusting and im running a T fittin off the intake manifold into the BOV idk what eles to do..
Old May 9, 2010 | 06:35 PM
kyden's Avatar
Default Re: Compressor Surge!
yes you need some sort of bypass valve. are you trying to get it to blow off at idle? cause with any decent size turbo it's not happening.
Old May 9, 2010 | 06:49 PM
alejandroDC2's Avatar
i have an RFL bov and i get flutter when it doesn't open at 10psi with my set up too. some bovs have stiffer springs than others and some can be adjusted. what kind of bov do u have?
Old May 9, 2010 | 07:13 PM
Turbo-LS's Avatar
if there is an adjustment then loosen it up. also the bov should have a dedicated vacuum line preferably a larger one like the front nipple that used ot be hooked up for PCV system. and if your running pcv system then you need to do somethign about that as well
Old May 9, 2010 | 09:43 PM
JON_S13EF's Avatar
At such boost you should be ok without a BOV temporarily while you source out good BOV. Consider looking for DSM 1G or EVO Bov. Those are BOV are reliable and can be had for cheap. GL!
Old May 10, 2010 | 05:23 AM
k20powered's Avatar
i have a greddy RS bov and im runnin my vacuum line from a T off the pCV line
Old May 10, 2010 | 07:58 AM
E85B18's Avatar
If I were you I would run a dedicated vacuum line to the BOV. Mine T'd off the PCV line would not open the valve, switching to a dedicated line made a world of difference. If you are going to T it, go off the brake booster.
Old May 10, 2010 | 11:37 AM
Psychoteen101's Avatar
Yea the RFL BOV's are typically picky. I had mine T'ed originally and it would do that on ocassion. Give it its own line.
Hand_Fed
Apr 22, 2010 04:51 PM
boosted_duece
Nov 23, 2005 09:29 PM
iwhichisme
Jun 14, 2004 08:05 PM
oemDC2
Dec 27, 2003 08:52 PM
