Leakdown
Old Sep 28, 2005 | 04:26 AM
Cooch2005's Avatar
Default Leakdown
I searched and couldn't find anything on it, well i could, just not what i wanted to know..... so a leakdown is a test done to show how much and exactly where a leak occurs..... but how is it done? what is used to do this? what's the theory behind this that makes it so effective? AND WHY THE HELL DOESN'T ANYONE AROUND HERE HAVE THE EQUIPMENT TO DO IT!? like really, how much is involved in this?? or maybe it's just called something else here, cause it's really pissing me off that nobody can do one more me!
Old Sep 28, 2005 | 04:41 AM
Backk InTheDA's Avatar
I hate everything
Default Re: Leakdown (Cooch2005)
What is exactly leaking in your car? oil, water in the car? When my rubber screw boots were dry rotted, and water was leaking into on my pass side floor, i replaced the boots and then took a hose and sprayed my car down, because usually when i washed my car, water would leak it, but after i repalced the boots, i sprayed it, and no water.
So just what ever part is leaking, get some sort of liquad, i would use water, and then fill it, or spray w/ water, and see if it leaks.
hth
Old Sep 28, 2005 | 09:14 AM
95lstegman's Avatar
Default Re: Leakdown (BuilttB18C5)
he's talking about a leak-down test, genius. it has to do with the engine. go to any speed shop that actually works on cars and ask them. they should know exactly where to get it done [if they don't do it themselves].
dlenoxx
Dec 2, 2010 12:05 PM
cmc600rr
Apr 11, 2010 11:21 AM
hondateg08
Feb 18, 2009 07:58 PM
Speed 101
Jan 28, 2006 06:44 PM
