Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
water leakage
Old 03-30-2010, 05:19 AM
cmc600rr's Avatar
Default water leakage
2007 accord v6 6mt. Rainning a lot for 2 days. Got a puddle of water on the drivers floor around the pedals. Where is it leaking? The rest of the car is dry.
Old 04-06-2010, 05:49 AM
KWayRacing's Avatar
Default Re: water leakage
Its my experience that 98% of all H20 leaks in hondas can be attributed to the windshield sealing area. Water leaks are easy to find. Hose car with water get a flashlight find it.
Old 04-11-2010, 11:21 AM
90sedan's Avatar
We can't tell you that for sure, but as KwayRacing stated, more often than not a water leak in the front of the cabin is usually from the windshield seal. Has the windshield been replaced?
Grab a hose or a sprinkler and soak the car. Make sure you completely dry the area first, that way you are certain if it's leaking again. I would suggest checking the windshield first, but if that's not it, start hosing the car off from bottom to top. You may need to let it soak at each section for a couple of minutes.
Creature1
Honda Civic (2001 - 2005)
05-05-2014 10:13 AM
Mayorseed
11-01-2007 04:51 AM
Cooch2005
09-28-2005 09:14 AM
Truecure
11-03-2004 12:33 PM
crxaddikt
10-28-2002 02:35 PM
Quick Reply: water leakage
