which wg sits higher.
Old Jul 18, 2007 | 12:19 AM
mra4886's Avatar
Default which wg sits higher.
ok which wastegate sits higher so i know what my hood clearance is. tial 38mm or a turbonetics deltagate? anyone ever see these two sitting next to one another?
Old Jul 18, 2007 | 02:33 AM
DaveF's Avatar
Default Re: which wg sits higher. (mra4886)
i would have to say a tial is slightly taller then the deltagate.
Old Jul 18, 2007 | 03:47 AM
Autoworks's Avatar
Default Re: which wg sits higher. (dturbocivic)
Tial may be a little taller than the deltagate, but the Evolution and the Tial are the same height (compared the 2 on the last kit I did for a customer...working with hood clearance issues as well)
Old Jul 18, 2007 | 07:33 AM
mra4886's Avatar
Default Re: which wg sits higher. (Autoworks)
ok this is good news cause im bout to purchase a deltagate i just wanted to make sure it had more clearance first. thank you guys.
Old Jul 18, 2007 | 09:04 AM
Integra94's Avatar
Tial will sit higher. But if you find some good deals and decide to get tial, just take the top screw/vacuum nipple on the top so it doesnt hit your hood. Also turbosmart makes wastegates that are pretty low in height.
Old Jul 18, 2007 | 04:06 PM
mra4886's Avatar
Default Re: which wg sits higher. (Integra94)
well i just bought the deltagate. and im take the screw out the top to clear hood. its going on a ls with a drag manifold in a ef sedan
Old Jul 18, 2007 | 05:44 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mra4886 &raquo;</TD></TR><TR><TD CLASS="quote">well i just bought the deltagate. and im take the screw out the top to clear hood. its going on a ls with a drag manifold in a ef sedan</TD></TR></TABLE>
you made a huge mistake going with that gate over the tial.
Old Jul 18, 2007 | 05:55 PM
Bonestock98GS's Avatar
yea agree ^^^^ all the way. I heard the deltagate has boost creep like no other wastegate. U may have been better off with an EGAY wastegate j/p
Old Jul 18, 2007 | 06:32 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: which wg sits higher. (Bonestock98GS)
ok im not disagreeing here, but the deltagate isnt always at fault, again on the drag mani, it is the placement. and i never really saw creep til a 3" d.p.
30psi+ on our buick powered mustang for 4 years no problems, except breaking trannies.
to answer the o.p., on my eg, the tial sat up higher than the delta.
Old Jul 18, 2007 | 11:33 PM
mra4886's Avatar
Default Re: which wg sits higher. (boostedcivicsir)
well i hope i dont have boost creep. but it will be ran on the minfold it was made for. with a drag dp as well. so i hope it wont have any issues. but if it clears my hood then i dont think i made a mistake. i dont want a hole rubbed into it.
Old Jul 19, 2007 | 03:35 AM
DaveF's Avatar
ahhhh come on mikey, you got a bad attitude, brother!
back in the day (00-01) on my rev-hard kit. i was running on my ls long block, with 2.5inch dp/3inch exh and no cat, the boost would creep from 10-15 psi in every gear, and even more in 4th. using the deltagate. when we swapped to the tial 40, it had no problem holding steady.
Old Jul 19, 2007 | 05:29 AM
Mr. Badwrench
no bad attitude, back in the day on my drag kit on my b16 it was solid at 10 psi all the time, drag 2.5 dp 3" exh no cat. got a sick deal on the tial, went to 17 psi, and then the clutch went, then got the little t3 turbo.
not arguing dave, just posting my personal exp.
evans next friday, cant wait.
Old Jul 19, 2007 | 08:20 AM
mra4886's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">no bad attitude, back in the day on my drag kit on my b16 it was solid at 10 psi all the time, drag 2.5 dp 3" exh no cat. got a sick deal on the tial, went to 17 psi, and then the clutch went, then got the little t3 turbo.
well i hope mine does the same. so i can hold 10psi steady.
Old Jul 19, 2007 | 08:26 AM
ciremulb5's Avatar
even if I had minor fitment issues, I would go w/ the TiAL hands down. It's performance is unmatched, especially if you ever feel like blowing your engine and cranking up the boost.
Old Jul 19, 2007 | 09:31 AM
DaveF's Avatar
well i hope mine does the same. so i can hold 10psi steady.</TD></TR></TABLE>
Old Jul 19, 2007 | 11:16 PM
mra4886's Avatar
how is it arguing when all i did was say i hope mine does just like the other guy stated his did. thats just hopefully wishing.
Old Jul 20, 2007 | 04:27 AM
White Smoke's Avatar
i my honda
Global Mod
Deltagates DO SUCK. My friend is selling one, 35 bucks and it's yours. I would go with the turbo smart 38mm gate since it is just as short as the delta and has WAYYYYY better performance. Not only that, people normally sell them used for cheap because they were mislead to believe Tial is better and wanna "upgrade".
Old Jul 20, 2007 | 05:44 AM
tegdude227's Avatar
tial must have the choke hold on people around here
BobGnarly
Aug 9, 2004 11:13 AM
Nextelbuddy
Apr 6, 2004 02:26 PM
Nextelbuddy
Mar 26, 2004 01:26 PM
BoostedGSRBubble
Mar 5, 2003 07:45 PM
