anyone have any hood clearance issues with drag manifold and TIAL 38mm wastegate?
i am looking to upgrade wastegate from deltagate 35mm to tial 38mm wastegate. i already have a slight hood issue with the deltagate with my drag manifold and noticed that the TIAL unit looks like its taller. i dont want to get it if my hood wont close.. anyone ?
Re: anyone have any hood clearance issues with drag manifold and TIAL 38mm wastegate? (nextelbuddy)
you need to use the elbow adapter an then hook the tial to it. should be fine
it did not fit on my car 92 hatch. I had to get the elbow which puts the wastegate off to the side. It clears now with out a problem.
Re: anyone have any hood clearance issues with drag manifold and TIAL 38mm wastegate? (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">you need to use the elbow adapter an then hook the tial to it. should be fine</TD></TR></TABLE>
dammit lol where might one find this elbow adaptor and how much are they?
they are usually like 40 bucks you can get them from many places
i got mine from ben at importparts. i think it was like 40 bucks.
Moderator in Chief
I asked the same question a few months ago and jackasses were calling me a newb. https://honda-tech.com/zerothread?id=736556
The elbo sucks, it places the wg too close to the manifold to fab a dumbtube.
I ended up bashing in my hood frame to make it fit.
Re: anyone have any hood clearance issues with drag manifold and TIAL 38mm wastegate? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">I asked the same question a few months ago and jackasses were calling me a newb. https://honda-tech.com/zerothread?id=736556
I ended up bashing in my hood frame to make it fit.</TD></TR></TABLE>
I will post some pics of my dumptube that PSI fabed for me. It looks so sweet and dumps right down by my tires. Not sure how you mounted the tube one way will put it right near your manifold the other way will put it off the end of your manifold near the timing belt cover.
Re: anyone have any hood clearance issues with drag manifold and TIAL 38mm wastegate? (underpressure
i was told that the top nipple of the wastegate is supposed to be used for a electronic boost controller such as greddy profecb 2 like i have.... i havent been using it liek that. i have the deltagate and have been using the side nipple for my electronicd controller and it has been working fine is that wrong?
BoostedGSRBubble
03-05-2003 07:45 PM
