wastegate problems HKS
Old May 22, 2004 | 11:36 AM
SPOOLINTEG's Avatar
Default wastegate problems HKS
ok here is my problem,
I have a hks Wastegate with a 9.6lb spring, and the car is boosting up to 14lbs where my boost cut is set for....So the only thing I can thing of is that I have my vacuum not right on the wastegate.
I am not running a boost controller
how should the 2 wacuum sorces be set up on the wastegate?
Old May 24, 2004 | 07:20 AM
SPOOLINTEG's Avatar
Default Re: wastegate problems HKS (SPOOLINTEG)
ttt...come on does nobody know about this?
Old May 24, 2004 | 07:22 AM
Tinker219's Avatar
Take the hat off, and make sure that the valve is tightened down to the diaphram. Ive had three manifolds come back to me complaining of "boost creep", when every single time the nut has come loose/fallen off. Loctite is your new best friend.
Its that, or you have the wrong spring...
DelSolMarine
Apr 17, 2022 10:21 AM
Boosted00
Jan 19, 2018 01:51 PM
flangemastermike
Jun 13, 2007 04:46 AM
turbo se
Jun 13, 2003 11:33 AM
antarius
Nov 19, 2001 08:29 PM
