Weird MSD Qwerk
Old Jul 22, 2003 | 10:14 PM
88ZCRX's Avatar
Default Weird MSD Qwerk
I just installed my msd blaster ignition box, blaster 3 coil, and blaster cap. Now the car starts only after I let the key go back to the on position, instead of starting while in the start position(forward most position). Is this just an msd thing or what?
Old Jul 23, 2003 | 07:37 AM
JT's Avatar
JT
Default Re: Weird MSD Qwerk (88ZCRX)
Did you connect the power wire for the MSD unit directly to a constant 12v and not a switched power source?
Old Jul 23, 2003 | 08:14 AM
PM-Performance's Avatar
Default Re: Weird MSD Qwerk (JT)
yea i think you wired the power wrong .
weird thing is i did mine weird too , i rushed with mine and when i turned the key back from on to acc the car stayed running , i had to shut it off and tnhe acc to get acc.
thne when i went to obd1 it fixed it ? weird. but oh well
Old Jul 23, 2003 | 09:13 AM
88ZCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JT &raquo;</TD></TR><TR><TD CLASS="quote">Did you connect the power wire for the MSD unit directly to a constant 12v and not a switched power source?</TD></TR></TABLE>
It is on a switch, but I am not sure where my friend got the power to the switch from. I will check that tonight after I get off work. Its not really a big deal seeing as it still starts and turns off fine.
Adam Cohen
Feb 24, 2019 06:43 PM
ludeatomics
Mar 8, 2016 09:11 PM
d16civic111
13
Jul 6, 2006 06:16 PM
jefe
May 26, 2006 08:21 PM
Vtec92Civic
Aug 19, 2005 01:23 PM
