Need some help on MSD BLASTER SS ignition coil
Old Mar 6, 2016 | 06:45 AM
ludeatomics's Avatar
Icon4 Need some help on MSD BLASTER SS ignition coil
Hey guys... I just bought ignition coil MSD BLASTER SS for my 95 Prelude H23A1. I tryed to istalled it but having issues.. So Im goin to use the original harness power... I went check the wiring and the BLACK YELLOW is positive BLUE is ground But the YELLOW is has no power.. But when I use the battery and connect my multimeter using the positive post I get power.. I thought it was the ignition but when I crank it I get no power. I knw it goes to the distributor cap. Can anyone help or tell what that wire is for?? Thanks in advance.
Old Mar 6, 2016 | 09:57 AM
motoxxxman's Avatar
Default Re: Need some help on MSD BLASTER SS ignition coil
oh good lord.
A lot of people hate MSD products. I am one of the few that actually really likes them. But even I will tell you to not use that coil. just get a new OEM coil.
you're not gaining anything by using that MSD SS coil. In fact it's a downgrade, because you're not even using an MSD box.
Old Mar 7, 2016 | 12:36 PM
Thanks for the info
Old Mar 8, 2016 | 09:11 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
If you are replacing the factory external coil with a MSD SS coil, do the following:
Connect the large black/yellow and the large yellow wire together. You will also get your "+" power for the MSD coil from the black/yellow wire, so tap it in where convenient. Finally, connect the green wire from the distributor to the "-" terminal of the MSD coil.
Also, for proper tach operation, you may need to connect the blue wire from the original external 4-pin coil plug to the blue wire at the distributor's 2-pin plug.
ludeatomics
Mar 5, 2016 05:51 PM
Rodzknight
Jul 3, 2006 01:02 PM
juicedh22
Oct 9, 2004 05:45 AM
_oemek_
Aug 16, 2004 04:16 PM
