low tension ignition coil power feed
Can anyone on here point me in the direction of finding which wire the low tension ignition coil power feed is?
Thanks.
Thanks.
Re: low tension ignition coil power feed (hondakevin21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondakevin21 »</TD></TR><TR><TD CLASS="quote">Which wire are you talking about in detail? </TD></TR></TABLE>
That's what its called. The low tension ignition coil power feed. I know where the ignition coil is....and I believe there are 4 wires coming off it.
Re: low tension ignition coil power feed (jefe)
https://honda-tech.com/zerothread?id=1430824 Try this its all I've found.
Re: low tension ignition coil power feed (onefast93sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefast93sol »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1430824 Try this its all I've found.</TD></TR></TABLE>
Thanks for the find. Not sure it gives me what I need.
Bump one more time.
Bump one more time.
