No power to ignition coil
MM Gruppe B
Re: No power to ignition coil
If you have no power out to the Blk/Yel wire on the ignition switch when the key is turned to II(ON), then the ignition switch itself is probably faulty. At this age the plastic ignition switch housing can deform or break. This causes the contacts to not make. No contact, no power.
