Weird boost flutter issue.
I've had my setup on my car for a few months now and had it tuned and all that good stuff but have had a flutter issue. The car will do fine when I go through the gears if it has a good load on the motor. Holds 10psi with no problems. I have the flutter issue when the car is in a higher gear and I try to speed up and not gear down. It will flutter until it hits full boost and then it will be rock steady. Kinda like if I did a 20mph pull in 3rd it would happen. It sounds like ch ch ch ch ch ch when it does happen.
Any help with this would be awesome.
