Delta wastegate in delta mode
Old 08-02-2002, 09:23 PM
SolidSpruce's Avatar
Default Delta wastegate in delta mode
most people install their delta wastegate as a conventional wastegate - just to open when boost reaches a certain level, but i was also reading the little pamphlet that came with the wastegate, that says u can set it up in 'deltagate mode' which would be to also utilize the top hold on the wastegate....has anyone set it up in this fashion, and if so, what are the advantages? thanks in advance.
MARLON
Old 08-02-2002, 10:00 PM
B20-T's Avatar
Default Re: Delta wastegate in delta mode (SolidSpruce)
this is what i did..i hook up a vacum hose on the top nipple of the delta ,and the side nipple and tee them off..and hook one vacum line to my charage pipe..with a 10psi spring..
highmilehatch
10-15-2003 07:44 AM
killa_lude
10-01-2003 04:59 AM
1tyme
04-06-2003 05:47 PM
CRXRageD
04-27-2002 04:43 PM
whagkangmakulet
10-01-2001 11:34 AM
Quick Reply: Delta wastegate in delta mode
