wastegate ?'s
Old Jun 15, 2003 | 03:11 PM
ebp 99 si's Avatar
Default wastegate ?'s
i got my turbo kit on but they forgot to send me the wastegate
i talked to them and they said i had a choice of either a tial 35mm or a tial 38mm
i told them i wanted the tial 38mm
what is the differences between the 2 and what is the spring set for on the 38mm?
Old Jun 15, 2003 | 04:22 PM
Distorted's Avatar
Default Re: wastegate ?'s (ebp 99 si)
Mostly the Tial 38mm will support up to 30psi of boost as opposed to the 20psi calculated maximum of the Tial 35mm wastegates. Its somewhat of a hybrid between the 35mm and 40mm wastegates they make. I've had great success with it so far as a replacement for my Turbonetics Deltagate, which i HIGHLY recomend against using if you want to run any kind of boost under 15psi. Hope you like your Tial!
Old Jun 15, 2003 | 05:11 PM
ebp 99 si's Avatar
Default Re: wastegate ?'s (Distorted)
cool
i'm gonna be running stock boost for a lil while till i get more money together to build the motor
what is the spring set at on the 38mm?
i think he said 9lbs boost but i'm not for sure
Old Jun 15, 2003 | 05:53 PM
Flamenco-T's Avatar
you can get any springs you want on the tial, I think they go from .3, .45, .6 bar and etc..
stan
Old Jun 15, 2003 | 06:04 PM
ebp 99 si's Avatar
Default Re: wastegate ?'s (Flamenco-T)
he never told me what spring was in it
i think he just said it would be around 9lbs
Old Jun 15, 2003 | 07:45 PM
evoeone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Distorted &raquo;</TD></TR><TR><TD CLASS="quote"> i HIGHLY recomend against using if you want to run any kind of boost under 15psi. Hope you like your Tial!</TD></TR></TABLE>even tial says a bigger wastegate is meant for low boost applications cause youre using less gas,
anyways, you should be fine, ive seen 400whp VR6 with just 35mm and 200whp with 40mm, i mean i never heard of a tial spiking, so as long as its a tial your good
Black DC2
Feb 9, 2005 08:20 PM
GSRswapandslow.
Jun 17, 2004 01:49 PM
7rrivera7
Nov 4, 2002 10:27 AM
TJ R
Feb 5, 2002 04:08 AM
