wastegate questions
Old Sep 2, 2011 | 10:46 AM
ekracing's Avatar
Default wastegate questions
i got a turbonetics evolution wastegete, got from e-bay used i was woundering if the gap around the valve seat normal or is there somthing wrong, is there some kind of gasket to seal it? looks like it will leak.
also can anyone tell me what psi this spring is
Old Sep 2, 2011 | 11:01 AM
BoostedDOHCGSR's Avatar
10 Year Member
Default Re: wastegate questions
Looks like its missing a Fire Ring.
Old Sep 2, 2011 | 11:43 AM
BigMike0147's Avatar
BINGO. Not sure on the spring rate tho
Old Sep 2, 2011 | 11:48 AM
ekracing's Avatar
did some research and alot o people say the turbonetics don't need one. does someone know for sure.
Old Sep 2, 2011 | 12:23 PM
I'm not the smartest person, but I know that SOMETHING needs to fill that gap. Typically there is a ring that sits there to create the seal (made of metal). If you try to put that on your car now, it's just going to be a new route for the exhaust.
Old Sep 2, 2011 | 12:32 PM
Hidenplanvew's Avatar
You need the fire ring... Im sure you can contact someone... Who ever said you can use it with out a firering is dumb and dosent have a turbo car
Old Sep 2, 2011 | 01:42 PM
ekracing's Avatar
been lookin and cant seem to find one for mine i wounder if i can use the tial? any one know who i can contact, tried turbonetics but they were already closed.
turbohatch96y7's Avatar
I had an older turbonetics at one time and there was an adjustment for that valve take it apart and check .
Old Sep 2, 2011 | 05:31 PM
ekracing's Avatar
Yeah I can adjust the valve down there is still a gap all around it maybe the fire ring gasket will fill it I gotta get one to see
Old Sep 3, 2011 | 04:03 PM
boostedteg909's Avatar
im runnin the evolution right now nd im using a fire ring. works great. no leaks. dnt kno wat spring u got there tho :/
Old Sep 4, 2011 | 03:31 AM
ekracing's Avatar
Did yours come with one, if not can I use a tial? If so what size,
Old Sep 4, 2011 | 07:35 PM
ya it came wit it when i bought it. u might b able to use the tial one if its the same mm diameter
Old Sep 4, 2011 | 07:42 PM
siblues's Avatar
Measure to see what size you need and someone on here will chime in on what size the tial is?
Old Sep 6, 2011 | 02:54 PM
ekracing's Avatar
UPDATE!! I think i found it summit racing or jegs has a turbonetics valve seat, i hope it works, 13.99 i have to wait for it to get here to see.
http://www.summitracing.com/parts/TNT-20763/
Old Sep 20, 2011 | 01:10 PM
ekracing's Avatar
got it today it fits!! was tight but i used a rubber mallet to tap it in, the valve still moves up and down cool deal
it was part number 20763, valve seat, got the invoice came from turbonetics if anyone needs to know, made for the evolution eastegate. it was like 17 bucks or so with shipping
chunkybs
Apr 13, 2008 08:17 AM
ham
Sep 2, 2007 01:08 PM
Flexin5
Jan 4, 2007 04:25 PM
twkdCD595
Feb 2, 2006 11:27 AM
swlabhot
Nov 10, 2003 02:04 PM
