tial 44mm wastegate - supposed to leak?
I just bolted on a brand new tial 44mm wg on my hatch (7psi spring), and started it up. I didnt have time to make a dump for it yet so its open right at the gate. When I started up the car I heard an exhaust leak. I thought it was the vband flange but it was coming from the outlet. I pulled it off and I could see light between the valve and the seat on the WG. Are they supposed to leak? I didnt see this with my tial 38mm...
Re: tial 44mm wastegate - supposed to leak? (MidwestAutoWorks)
i need pics.... i must be missing something.
the one that i bought was an open package... i knew something was missing...
if you hooked the top port of the gate to a normally open boost control solenoid it will suck the gate open with vacuum from the motor . if you running a small spring that is
Re: tial 44mm wastegate - supposed to leak? (93CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX »</TD></TR><TR><TD CLASS="quote">Ouch, that sucks. It does indeed sound like the fire ring.. where did you buy the opened package?</TD></TR></TABLE>
i got it from tuning factory. i bought it brand new unopened, then returned it. they never put the balance back on my credit card, and then they went under. i called them up and said they better at least give me my wastegate back, and they did.... except it was an opened package and one of the flanges was used.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
thats not a firering thats a flange. the fire ring is the smaller ring in this picture.
HT White Ops
Re: tial 44mm wastegate - supposed to leak? (Lamchop0000)
In the picture the firering is still on the gate BUT in that same picture they have another one sitting in front of the clamps. There are 2 clamps and then the ring. You could also call it a valve seat if that helps you.
OP on your gate if you look inside from the outlet in, is the valve completely sealed around or can you see a slight gap between the valve and the gate body?
Re: tial 44mm wastegate - supposed to leak? (ham)
im retarded... i just looked in the bottom of the box and the firing ring was right there. problem is gone!
