Wastegate operation?
Old Mar 4, 2009 | 10:05 AM
keving85's Avatar
Default Wastegate operation?
Hi I just have a quick question. I have my dump tube running open loop right now and during normal driving it sounds like a small exhaust leak coming out of the. Dump tube. Is this normal? I hear it open all the way up when I reach full boost. I Am worried about the small amount that I hear while driving
B18 b1 turbo cams with 7 lbs spring in wastegate
Thanks. keV
Old Mar 4, 2009 | 11:34 AM
TheShodan's Avatar
Moderator
Default Re: Wastegate operation?
That's normal, since the wastegate is opening into the atmosphere. venting out that exhaust is very aggressive and loud.
Old Mar 4, 2009 | 12:16 PM
keving85's Avatar
So it's normal while driving just around town even keeping it out of boost. I mean it just sounds like a small exhaust leak. I figured it would stay completly closed til you reach the 7psi.
Old Mar 4, 2009 | 12:33 PM
dart2.2's Avatar
is your fire ring in your wastegate?
Old Mar 4, 2009 | 12:43 PM
keving85's Avatar
Yeah it is and so is the valve seat. It is leaking all the way back to the end of the dump tube. Brand new rev hard wastegate.
Old Mar 4, 2009 | 05:10 PM
keving85's Avatar
anyone is this right
Old Mar 4, 2009 | 08:04 PM
keving85's Avatar
Bump
Old Mar 4, 2009 | 09:01 PM
dc4-b20's Avatar
do you have all your gaskets in place?
Old Mar 4, 2009 | 09:17 PM
keving85's Avatar
Yes I have triple checked them it is leaking past the valve in the wastegate it is sealed at idle but when taking off from a stop it will leak past the wastegate. As if the valve is opening
Old Mar 5, 2009 | 02:06 AM
SD_Lurker's Avatar
HT White Ops
It shouldn't be sounding like a leak if you aren't in boost. When it starts creating desired boost the gate will begin to open up and sound something like an exhaust leak. Under normal driving conditions it should not sound like that.
Old Mar 5, 2009 | 05:40 AM
SovXietday's Avatar
If you create any kind of boost with a light spring you will crack the wastegate. If you're opening the wastegate under vacuum you've got other problems.
Old Mar 5, 2009 | 05:52 AM
dpetro1's Avatar
take the dumptube off and confirm that its open under vacuum. if so maybe take it apart and check the diapraghm
Old Mar 5, 2009 | 12:12 PM
keving85's Avatar
I will apply some vacum to the. Wastegate tonight and goose it. A little and see it the noise goes away
Bizzle5OH3
Sep 29, 2010 06:49 AM
dagle
Feb 9, 2008 12:51 PM
specie
Feb 5, 2004 09:38 AM
Chuck Dean
Aug 9, 2003 04:20 PM
echo999
May 21, 2002 05:47 PM
