Which Wastegate gasket is better?
Re: Which Wastegate gasket is better? (AF-P Dunc)
The "fire-ring" on a Tial wastegate is actually the valve seat, so you have to use a fire ring. Running with just the fire-ring works much better than crap gaskets that are prone to blow out. Those thin metal gaskets work pretty well too.
Just run no gasket, you'll be fine.
Re: Which Wastegate gasket is better? (bb_one)
alright cool, because mine just blew out and i lost a bolt holding the wastegate to the manifold (which was kinda scary since the other one was almost off too) thanks for the responses guys.
Re: Which Wastegate gasket is better? (95dc2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Permatex® Ultra Copper® Maximum Temperature RTV Silicone Gasket Maker
OEM specified. Highest operating temperatures for 4-cylinder, turbocharged or high-performance engines. The most advanced, high temp RTV silicone gasket available. Sensor-safe, low odor, noncorrosive. Superior adhesion. Three times more oil resistant than conventional silicones; eight times more flexible than cut gaskets. Temperature range -75°F to 700°F (-59°C to 371°C) intermittent; resists auto and shop fluids and vibration.
Suggested Applications: Exhaust manifolds/ headers, valve covers, oil pans, timing covers, water pumps, thermostat housings</TD></TR></TABLE>
I run this.
1 - A lot cheaper than buying gaskets all the time.
2 - It works...and the specifications fit exactly what you'd be using it for.
3 - It's a gasket - and that's better than no gasket. If "no gasket" was best than why do OEMs spend billions on gaskets for their engines? They aren't for decoration.
