hondata with a boost controler
Old Apr 17, 2004 | 01:59 PM
Ls-Rturbo's Avatar
Default hondata with a boost controler
I got a deal on boost controler but befor I buy one I wanted to know how it works with hondata?
I got a 99ls and my set up consist of a t3/t04e, tial wastgate 7psi spring,blah blah
but my probley is that with the stock exhast it dont boost more than 5 unless i unbolt my exhast witch yields 7psi. I am also running the stock 95ls ecu with plans to get hondata and bigger than stock injectors. SO how dose the the boost controler work with hondata if when u get ur car dyno'ed at mabey 10 psi and u turn it up to 12 then things arent tuned to good right??? or can u event use hondata with a boostcontroler
Old Apr 17, 2004 | 02:55 PM
EG6owner-T's Avatar
Default Re: hondata with a boost controler (bl18t)
hondata and boost controller are different, you can get either first...
hondata controls fuel and ignition maps etc.
boost controller control the wastegate where its only connected to
Old Apr 17, 2004 | 04:03 PM
baphomet's Avatar
Default Re: hondata with a boost controler (EG6owner)
Make sure you are tuned for the higher boost before you turn it up.
What kind of management do you have now?
Old Apr 17, 2004 | 10:09 PM
Ls-Rturbo's Avatar
Default Re: hondata with a boost controler (devnull)
im running the stock injectors with a FMU 12:1, intake fuel pump, b&m FPR
Old Apr 17, 2004 | 10:45 PM
EG6owner-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bl18t &raquo;</TD></TR><TR><TD CLASS="quote">im running the stock injectors with a FMU 12:1, intake fuel pump, b&m FPR</TD></TR></TABLE>
than you can boost it to no more than 10 psi if you feel like it
Old Apr 18, 2004 | 09:40 AM
Ls-Rturbo's Avatar
ya 10psi is what i planed on unless i got some race gas for the track.
Old Apr 18, 2004 | 10:41 AM
EG6owner-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bl18t &raquo;</TD></TR><TR><TD CLASS="quote">ya 10psi is what i planed on unless i got some race gas for the track.</TD></TR></TABLE>
once you go with hondata get a 3 bar map sensor and have someone tune it to 12-14 lbs...
Old Apr 19, 2004 | 10:03 PM
crazy eyez killa
Guest
Posts: n/a
youre going to blow your motor up brian
Old Apr 20, 2004 | 03:51 PM
Ls-Rturbo's Avatar
Default Re: hondata with a boost controler (Vortech99Si)
na **** aint gonna blow 4:20
Old Apr 20, 2004 | 05:43 PM
crazy eyez killa
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bl18t &raquo;</TD></TR><TR><TD CLASS="quote">4:20</TD></TR></TABLE>
fo' twenty
&lt;&lt; me
pwrofdrm
Engine Management and Tuning
Oct 10, 2008 06:47 AM
1.8turbolsvtec
Apr 25, 2004 03:59 AM
