warped block?
Old Dec 11, 2007 | 07:31 PM
panda_eh2's Avatar
Default warped block?
can your block warp? i've been having problems with my coolant lines exploading for a while, i have arp headstuds and checked to make sure my head was level again. but still there is air getting into my coolant system making hoses expload. gsr turbo with eagle rods je 81.5mm pistons, honda headgasket, blockguard. is it possible that my block is warped
Old Dec 11, 2007 | 07:37 PM
SD_Lurker's Avatar
HT White Ops
Default Re: warped block? (panda_eh2)
absolutely is possible to have an uneven deck. has the block every been resurfaced? have you had any prior overheating issues with this engine?
Old Dec 11, 2007 | 09:29 PM
panda_eh2's Avatar
no i didnt have any problems untill i put the motor back together. i know the head was decked when i had the block bored, but i dont know if they cut the block too.
Old Dec 12, 2007 | 04:13 AM
Mikey3000's Avatar
Default Re: (panda_eh2)
you need a straight edge to check for flatness on the head and block surfaces.
Old Dec 12, 2007 | 09:27 AM
panda_eh2's Avatar
do i just run it flat across the top and look for gaps? is there anything else that could make this hapen?
Old Dec 12, 2007 | 10:08 AM
Muckman's Avatar
Moderator in Chief
You have a blown head gasket possibly from a bad seal or a bad tune.
Old Dec 12, 2007 | 10:29 AM
Mikey3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by panda_eh2 &raquo;</TD></TR><TR><TD CLASS="quote">do i just run it flat across the top and look for gaps? is there anything else that could make this hapen?</TD></TR></TABLE>
yeah you lay the straight edge on the surface and look for gaps or try to slide a feeler gauge between the straight edge and the surface. do this in several locations on the head-block mating surfaces. but like Muckman said, check for blown head gasket 1st as that is a more likely problem. warpage happens when head bolts/studs weren't torqued correctly or in the right sequence.
Old Dec 12, 2007 | 06:12 PM
panda_eh2's Avatar
i've replaced the gasket 3 times
Old Dec 26, 2007 | 10:21 PM
mouab18c1's Avatar
same problem...i had that milky crap in my head...changed my headgasket....start it running for 10 minutes and still have that shyt...is it from the leftover oil/coolant mix in the block...resurfaced the head before that also....
Old Dec 27, 2007 | 08:52 AM
blackeg's Avatar
Default Re: (mouab18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mouab18c1 &raquo;</TD></TR><TR><TD CLASS="quote">same problem...i had that milky crap in my head...changed my headgasket....start it running for 10 minutes and still have that shyt...is it from the leftover oil/coolant mix in the block...resurfaced the head before that also....</TD></TR></TABLE>
ive got the milky **** bad right now. im gonna resurface the head and replace the headgasket.
the head is more likely to warp than the block i think, considering it is smaller and has less material to absorb heat in case it gets too hot.
are you running a stock or an aftermarket block?
Old Dec 27, 2007 | 11:19 AM
mouab18c1's Avatar
Default Re: (blackeg)
just a stock b20b4 bottem end....gives me headaches...
Old Dec 27, 2007 | 08:03 PM
SteamedRice's Avatar
have the deck resurfaced and run a thick metal gasket
Old Dec 27, 2007 | 11:32 PM
mouab18c1's Avatar
Default Re: (SteamedRice)
thought about....too lazy to pull it out again.thinking about selling it if i take it out....
10SecDSM
Sep 15, 2006 08:11 AM
YashiMotors
18
Jun 29, 2006 05:48 PM
YashiMotors
Jun 26, 2006 11:47 AM
hmtcrxsir
Mar 25, 2006 04:27 PM
Lewcis
Jul 29, 2004 09:19 PM
