V-AFC hack... with 310cc injectors instead of 450's
Old Feb 3, 2004 | 04:59 PM
89 CRX SI's Avatar
Default V-AFC hack... with 310cc injectors instead of 450's
i know u set it to -40 for the 450 cc but with the 310's since there not as much as twice the size would u set the afc to like -30???
Tory
Old Feb 3, 2004 | 05:36 PM
R@mon's Avatar
Default Re: V-AFC hack... with 310cc injectors instead of 450's (89 CRX SI)
you can but now the highest amount of boost you can run is lower due to the fact that you arent cutting the signal enough
Old Feb 3, 2004 | 06:01 PM
b16ahybrid's Avatar
if your going to run the 310's i'd recomend throwing a fmu in there too. Maybe a 6:1 or even a 4:1 to get a little higher fuel pressure under boost, then use the v-afc to fine tune the fuel curve. Not exactly the hack, but it works good for me....
I'm runing 310's,4:1fmu, sfc (leaning out). For my fuel. My fuel pressure has not gone over 85psi (still high but do-able)
JadecrewGSR
Apr 26, 2005 08:28 PM
NeXtLeVeL_TyPe_R
Jul 26, 2003 11:58 PM
EggEX2000
Jun 1, 2003 01:16 PM
wontonracer
Mar 16, 2003 06:05 PM
1SpoolnH
Sep 30, 2002 05:15 PM
