Want to run 1 bar of boost using hack on built engine.
Hi
Here is what I want to do. I want to run 1 bar (14.5psi) of boost on my built b16 and still keep with my 450 injectors, my apex i vafc and my MSD btm. The only thing is a can't run Hondata on a euro spec PW0 ecu and I have not got a very large budget. So hit me back with some answers. |
Re: Want to run 1 bar of boost using hack on built engine. (NOSED_CRX_VTEC)
There is a big thread on uberdata. I think you should check that out.
1 bar is pretty risky with the hack. Not to mention if you can even get that much boost without a cell... It's been done, but I wouldn't trust it.
Re: Want to run 1 bar of boost using hack on built engine. (5thgencivic)
get a three bar map sensor and some tuning and you should be ok.
Re: Want to run 1 bar of boost using hack on built engine. (InTeGrA B18b1)
I dont' know if the "hack" will work with a 3 bar, a 3 bar will alter the voltage.
Re: Want to run 1 bar of boost using hack on built engine. (Mpir3)
you can run the hondata stage 4b on the pwo ecu
If I remember right the afc can only go as high as 3.5v or 5v(I can't remember which) In order to reach a 1 bar you'd have to go beyond the stock map sensors "reading" ability. Those of which that have gotten to 1 bar without a different map sensor and no CEL are either lying, gotten lucky, saw a millisecond boost spike, or their CEL light went out. In order to reach your goal safely I would save up a little more money and get some 550 injectors and a semi-standalone. Anything past the stock map sensor's ability is just asking for trouble.
Re: Want to run 1 bar of boost using hack on built engine. (Redlineracer)
i read somewhere that the hack will work with a 3 bar if you change the sensor in out selector on the afc, this manipulates the voltage. Let me see if i can find the thread, I doubt it but I will try.
Rob EDIT: I cant believe I found it, and only after 2 minutes of searching. Check it out https://honda-tech.com/zerothread?id=531705 Modified by rjardy at 3:06 AM 9/27/2003 |
Re: Want to run 1 bar of boost using hack on built engine. (90civichbsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi »</TD></TR><TR><TD CLASS="quote">you can run the hondata stage 4b on the pwo ecu</TD></TR></TABLE>
I can't use this system cos it don't work on euro spec only on jdm and usdm ecu's cos they use a knock sensor. I can either get a jdm pwo ecu and a knock sensor and then run hondata stage 4b or swap to a obd1 ecu from a later honda and run S200 but then I got to then change the dizzy for the later honda and fit a 4 wire o2 sensor. All of that will cost the big ££££££££ cos I'm in the UK. Any more ideas |
Re: Want to run 1 bar of boost using hack on built engine. (rjardy)
did you not see my post?
Rob |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy »</TD></TR><TR><TD CLASS="quote">i read somewhere that the hack will work with a 3 bar if you change the sensor in out selector on the afc, this manipulates the voltage. Let me see if i can find the thread, I doubt it but I will try.
Rob EDIT: I cant believe I found it, and only after 2 minutes of searching. Check it out https://honda-tech.com/zerothread?id=531705 Modified by rjardy at 3:06 AM 9/27/2003</TD></TR></TABLE> Wow! https://honda-tech.com/forums/images...s/emsmileo.gif Thats pretty cool man Good Job! https://honda-tech.com/forums/images/smilies/emthup.gif |
