3 bar map sensor needed to boost?
Old Oct 24, 2003 | 11:45 AM
2ltrsnailpwr's Avatar
Default 3 bar map sensor needed to boost?
In conjunction w/ aem ems do i still need a 3 bar map to exceed 1 bar?
seems obvious but just want to make sure----where's best buy ??
Thanks-- cars being dynoed/tuned next week
Old Oct 24, 2003 | 12:07 PM
99integralsturbo's Avatar
Default Re: 3 bar map sensor needed to boost? (B18egHatch)
i dont want to be a dick but this was covered in almost an exact thread a couple of days ago try searching but here is the answer anyways
yes you do because the EMS needs to be able to read boost to properly run the car, the factory can not read over 1 bar
Old Oct 24, 2003 | 12:39 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: 3 bar map sensor needed to boost? (99integralsturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99integralsturbo &raquo;</TD></TR><TR><TD CLASS="quote">i dont want to be a dick but this was covered in almost an exact thread a couple of days ago try searching but here is the answer anyways
yes you do because the EMS needs to be able to read boost to properly run the car, the factory can not read over 1 bar </TD></TR></TABLE>
I wish the factory stoped at 1bar=14.7psi. It actually .80bar psi.-11
Old Oct 26, 2003 | 07:11 PM
Default Re: 3 bar map sensor needed to boost? (HybridcivicLS-T)
ok good one u got me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">
I wish the factory stoped at 1bar=14.7psi. It actually .80bar psi.-11</TD></TR></TABLE>
thanks for pointing it out, i knew that but didnt think of it
sakasaku
Oct 28, 2010 10:51 AM
insaneconceptz
Mar 4, 2009 05:35 AM
Turbocivic94
Feb 27, 2006 09:11 AM
-iLLuZioN-B18C1
Sep 18, 2003 11:08 AM
